2 12" in CADDY!! ***iphone vid!!!!! pg4.
oh ohkay. I was thinking 35 or atleast that's what RE told meh. But which should play some good lows too?
hey so i measured out every thing and this is what it came up to be. is this going to be fine?? idk much. also how does the port area look lyke?? do yu think it will make any port noise??
I could not find that model of re sub but I think a 1200 watt amp would be a safe bet 600 for each sub
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
I wouldn't do sub and port up. Do sub and port back for best results in a trunk car. Is it possible that you could change your depth from 14" to 20"?
[/quote
nah man thats all i could do?? ):
Damn. I was playin with some dimensions and got it right at 35hz with a 20" depth. I couldn't get that with 14, not sure why.
what do yu mean?? do i not have a 34 hz port??
well started on the box and this is what it looks like. what do yall think. this shyt pounds well idk really but i only had enough wire to hook up ONE COIL OF ONE WOOFER and tryed it out any wow it sounded sick for one coil. anyways to the pics.
fuel for the system!!!
smooth edges
mixing up some resin.
first side resin and fiberglassed.
resin for now i lost the fiberglass ):
some signatures from the people that helped.
and the fam just chilling outside.
are you on crack or something? That's not a Caddy
2015 Mazda 6
JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm
2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i
NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
