just got the 4's put on and got a skinny tire because i was planning on lowering it a few inches but the only kit i can find is a ground force kit 1.6" front and back..anyone know where i can get something different? maybe like 2.5-3 inches max
2004 Explorer Limited
24" Lexani "pyros" wrapped in 255/30/24 pirelli's
270 Amp MechMan Alt.
(2)Stinger SPP-2150's
(2)Sundown NightShade 15's
IA 40.1
sry for off topic, but howd you get 24's to fit
2002 ford explorer
200 amp rewound alt
single 18" Fi btl fully loaded
2 1750's
2 c&d tech 88amp/hr batts
2 ought wiring
cdt component set up front, cdt coaxials in back
Kenwood eXcelon KDC-X693
so you think just sticking with the springs all the way around is the way to go?
They fit right on, no rubbing no issues what so ever i can pull a u turn with no issues...but then again they are on a 255/30 tire so it's a pretty skinny tire..hell with all the room left i coul've probably done a 40 series tire and still been good.. i think the newer gen explorers have a lot more room because a buddy of mine has 23's on his 97 and they rub a tad bit when he turns
IA 40.1
anyone have anymore input? looking to get the stuff ordered by friday so i can install whatever I get on my vacation next week.
IA 40.1
1.6" will change the look alot. if its coil sprung you can sometimes remove the isolator (rubber piece above the spring) and stick a thinner strip in there, the isolator is usually there to simply "isolate" the noise coming off the rims and tires, but i doubt it would make that much of a diff, and might get you another .5"
DCAUDIO
BALLS DEEP
  • Who's Online   0 Members, 0 Anonymous, 1289 Guests (See full list)
