I should know this, but haven't tested anything yet. I'am an electrician, but before testing was hoping someone just "knew" what these were, especially if they go to the Brain, or air bag system- no yellow coding, so I'am pretty sure Iam safe.....
What I want to do is place my mirror/window/lock controls in my center console I will be modifying here soon.
The black box pretty much seems to have the same color coding as the passenger door, and since the plug is on the right/pass side, assuming there is a connection?
There is a box close by, maybe these plug in to the box, saying "Body Controls"
Are you trying to move that? It is the body control module, I don't know why GM put it there. I think the airbag control module is farther up and is the one with the yellow convoluted tubing.
You also have to run everything to the actual switches on the door, or nothing will work. You have mirror, lock and window controls rignt? None of the heated seats options?
I have every option possible on this
after a few hrs of reading, yes these plugs do go directly to the doors/seats etc
I will be messing with it a little in the rain today
Iam fully glassing the doors, and its taking to much time to mold the switch panel in to the doors like I wanted so this will be easier this way
i dont see it being a problem doing that. all you would have to do is maybe run the wires a little longer so that they will reach. same thing as relocating heater control which i still have to do.
edit: just make sure you keep the plastic things that make the shit work. cause your gonna need those. just glass them into the center consol. easy shit.
Edited by B slaps yo mama
I Rock 4 Doors 4 More Whores!
SMD SUPER SELLER
my seller feedback http://www.stevemead...-mama-feedback/
more seller feedback http://www.stevemead...-slaps-yo-mama/
