Using A sub amp RCA Pass Thru ?
Crump
Ok so Ill be running a RF P-200-2 on my tweeters, and 4 channel doesnt have a passthrough for the RCA's, can I just use the Sub amps Pass through?
Also will turning the sub off on the deck turn off the tweeters I will be connecting to the P-200-2 if I use the sub amp's RCA Pass throughs?
you'll be better off just using rca splitters.
yes go with the slpitter instead
2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG.
so which ones should I split either the front or the rears? which or does it not matter
and will I lose anything by splitting it?
I'm assuming you only have front and rear preouts.
Split the rears. And you will not notice any difference in the response of either.
Need an install? Hit me up.
[email protected]
Got car audio questions? Check here first!
Everything you need to know. =]
http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
Cool, thanks, and no I have front, rear and sub, my 4 channel has no outputs for the RCA's but the sub amp does, but Ill just split the rears and run the amp that way
Agghh post fail. Split the fronts since you're running tweeters. So you're adding a third amp then? I didn't read the first post carefully sorry.
[email protected]
Yes what frog said, just use splitter off the front RCAs
and yes frog, he will be running the tweets off a p200
2001 Bravada (2wd) Pewter on 24's
JVC KW-AV60BT
10 Alpine Type-S 6.5s
2 PSI/BTL 18's @ 32Hz
2 Rockford Fosgate T25001-bd's @ 1-ohm each
Rockford Fosgate T1000-4
Rockford Fosgate T400-4
Rockford 3Sixty.2
Yellow top up front, 2 9a31s in the back
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
i didnt see the video or read anything but...cool story
and the reason your being a cock tonight is?
So do I want these?
My link
or these
My link
and how many do I need?
Your going to be splitting two male ends into four male ends so you'll need 2x one female to two male.
[email protected]
  • Who's Online   0 Members, 0 Anonymous, 1369 Guests (See full list)
