Testing an amps output
How can I test my amplifiers output? I know there was a post about it but I can't seem to find it. I have a clamp meter and I have a DMM....now what do I do with them?
d(-__-)b
beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
You put the clamp meter around the speaker lead out of the amp and you voltmeter in the speaker terminal with it set to AC record the voltage and amperage.
edit: I can't spell today....
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
Clamp meter around both wires coming out of the amp? and take the Pos and ground lead from the meter to the pos and neg on the amp. Get me reading and then....?
d(-__-)b
Here you go.
http://www.stevemeadedesigns.com/board/topic/23462-check-actual-ouput-of-an-amplifier/
There is a nice little wattage calc at the end of page 2.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
  • Who's Online   0 Members, 0 Anonymous, 854 Guests (See full list)
