So when i try to hook my meter up its not showing the voltage the stinger part lights but the voltage doesn't light up at all. Could this be because it is broken or like a faulty meter? One more thing. When i had my cap in and i had my meter in it worked but then when i took my cap out and added a battery it doesn't work. Any suggestions?
Thanks,
Kasey
Thanks,
Kasey
check your wires mine has done this and thats what was wrong with mine
Well i took it all the way out and i just have the 3 wires Power(Red) Black(Ground) Blue(Remote). And i put the ground on the - on the bat and the Power in the + and only the stinger lights up.
the blue wire needs power to for it to work
Run the remote wire with the power wire and it should come on.
I did that and all that happens is the light on the "Stinger" part gets brighter. And the voltage part doesn't light up.
