hdorre Posted April 15, 2010 Report Posted April 15, 2010 I'll be getting 4 12s and want the subs to play low. I've heard that Qs are SQ subs and SSDs are SPL subs. Does that mean the SSD is sloppy? Here's the enclosure: about 9.5 cubes after port displacement and is tuned to about 33hz. Which setup would hit the lows harder and move more air? 1) 4 12" Fi SSDs with Flatwind coil on two Rockford Fosgate T1500-bds 2) 4 12" Fi Qs on two Hifonics 2610ds On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
Moti Posted April 16, 2010 Report Posted April 16, 2010 It doesn't make sense that you are getting lower quality amps for the Q's and better quality amps for the SSD. It doesn't mean that the SSD's are sloppy, everything will sound good in the proper box. Personally I would pair the Q's with the RF amps. I am sure they will birth higher, so wattage shouldn't be an issue.
Crump Posted April 16, 2010 Report Posted April 16, 2010 If you want to play LOW get the Qs with the fosgates not the Hifonics. Team gg Team doa Installs I have doneMy 2010 Rebuild 144 db so far....2 DC xl 10s Firing into cabin on a RF 25002 12" AQ HD's powered by a Saz 2k + Lots o Mids+Highs
Twistedchild420 Posted April 16, 2010 Report Posted April 16, 2010 SSD's are louder.....that's all that counts My POS Bass machine-2003 Hyundai Santa Fe on some shitty 22'sBed Liner Paint Job-Pioneer AVH 3200DVD4 DAD BD series 15's in a 4th Order (Bassheads ENT Design)4 Arc Audio XDI2000.1 for the woofers6 Cadence CVL68MBX 6.5's-Cadence CVL88MBX 8's-6 Cadence XT20 Supertweeters2 Arc Audio KS300.4's for mids and tweets1 Arc Audio ALD 10v Line DriverAll Audiotechnix Power wire1 DC Power 270XP High Output Alternator1 XS Power D3400 up front....6 XS Power D3100's in the rearAir Lift 1000 Bags in rear to help with suspensionIf your still reading this GFY.......
hdorre Posted April 16, 2010 Author Report Posted April 16, 2010 It doesn't make sense that you are getting lower quality amps for the Q's and better quality amps for the SSD. It doesn't mean that the SSD's are sloppy, everything will sound good in the proper box. Personally I would pair the Q's with the RF amps. I am sure they will birth higher, so wattage shouldn't be an issue. I put the ssds with fosgate amps because it would be cheaper. I'm expecting them to put out around 1600-1700 watts rms which is right around the power range. If I put two Qs per amp, which fosgate amp would you reccomend? They aren't still making the T2000 On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
hdorre Posted April 16, 2010 Author Report Posted April 16, 2010 I put the ssds with fosgate amps because it would be cheaper. I'm expecting them to put out around 1600-1700 watts rms which is right around the power range. If I put two Qs per amp, which fosgate amp would you reccomend? They aren't still making the T2000 Or would this setup be better (Hit lower): 2 Fully loaded 18" BTLs in a 10 cubic foot box tuned to about 32Hz with a Rockford Fosgate T2500-1bd powering each sub On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
Moti Posted April 16, 2010 Report Posted April 16, 2010 Any of the subs will sound good in the right box. The q's get really low. The thing with q's is you can use them in a budget sq setup if you really needed to, that's how good they are in terms of sound quality. If that doesn't matter, just go with the BTL and T2500's.
