Anyone have a HU wiring diagram? Im in the middle of doing mine and ive been searching for the accessory wire for 15 min. Im a bout to run it to the ignition column.
blue wire w/ white line.
or plain blue one.
84 K5 Blazer
3" body, 2" Suspension
35" Maxxis Bighorn
100amp Alt
Marine deep cycle for the amps (freebie)
KnuKonceptz 1/0
8 Hifonics HFi 12D4's in ~19cubes tuned to 35hz
Audiopipe AP-18001D
RF 5x8's in the kicks
Almani 5.25 comp. in back
Kenwood KAC-645
--IN THE FUTURE--
None.
<!--quoteo(post=0:date=Feb 3 2010, 09:12 AM:name=Decaf)--><div class='quotetop'>QUOTE (Decaf @ Feb 3 2010, 09:12 AM)</div><div class='quotemain'><!--quotec-->we seriously need some butt plugs so you guys stop spewing chit talk<!--QuoteEnd--></div><!--QuoteEEnd-->
u can run it with the power wire and put a switch on the dash. did it in my friends car. super easy and worked fine
BUILD LINK: http://www.stevemeadedesigns.com/board/topic/112034-2-sundown-18s-98-f-150/page__p__1565972__fromsearch__1#entry1565972
98 Ford F-150
Truck:
37" superswamper tsl radials
16" ion alloy wheels
3" body lift
2" suspension lift
Offbrand brushguard
PIAA driving lights
6000K HID's
System:
2 18" Sundown Nightshaed
Aq3500
Custom Fiberglass box
fosgate T1 6x8 Coxials
bass inferno 2000 watt 4 channel
2 XS power d3100's
0 Gauge
9 times out of 10 you'll forget to turn that off.
84 K5 Blazer
35" Maxxis Bighorn
100amp Alt
KnuKonceptz 1/0
Audiopipe AP-18001D
Kenwood KAC-645
--IN THE FUTURE--
None.
very true. but would it just be giving power to the led with the car off? or the amp still sucking power?
98 Ford F-150
Truck:
3" body lift
2" suspension lift
Offbrand brushguard
PIAA driving lights
6000K HID's
System:
Aq3500
2 XS power d3100's
0 Gauge
It will always be drawing power.
Like my amp has a 3A idle draw, which means it draws three amps just being turned on.
84 K5 Blazer
35" Maxxis Bighorn
100amp Alt
KnuKonceptz 1/0
Audiopipe AP-18001D
Kenwood KAC-645
--IN THE FUTURE--
None.
or plain blue one.
will go back out and look...Got to my ignition column and there was a block/harness that had 5V written on it in red marker. Havent put the DMM on it yet but im guessing that means 5 volt. Wondering what these wires could be.
To the suggestion of the switch. I have horrible memory, and always forget shit, but hey, that happens i guess. I would always forget to turn that thing off.
9 out of 10 times if you cant find a acessory wire its because the vehicle uses the data bus cable for the acessory. I am not 100% sure if it does but I am leaning that it does, just because most newer vehicles do. There is a easy way to determine this if your door chime runs through the door speakers then theres the problem.
I am going to tell you this through experience if you have a data bus wire and say fuck it and pull a acessory lead from some where else you are going to FUCK youre car up. The pcm constantly communicates with the radio and if you go ripping shit out and rigging the wires you will eventually burn up the pcm so I highly recomend you find a vehicle specific harness for this, it may be a bit difficult cause its a 2010.
There is no data bus to the HU. It had 2 regular pin connectors in the back.
are u still using the stock headunit?
Edited by manofthehour
My stuff
'06 Scion xA:
-Alpine iDa-x100
-Alpine KTP-445 Power Pack
-Polk Audio db6501 (front components)
-Polk Audio db651 (back coaxials)
-2 RE Audio SEX12D4s
-Cadence F1200-1D
- Custom box tuned to 33Hz
- Kinetik HC1400
- 50 ft2 of Audio Technix sound deadner
- Big 3
My photography page
  • Who's Online   0 Members, 0 Anonymous, 786 Guests (See full list)
