just get the 3500, no need for 2 amps when 2 of the 2200's basically = the 3500. your voltage drop wouldnt be bad at all, itll keep up fine.
I want to but I dont have a lot of room under the hood..its not like a GM, its a Mazda, so that means im gonna probably have to give something up. How would the 320 amp alt and 3 XS Power D3100s be? Do you think the voltage drop be horrible (under 13 volts?)
Edit: Nevermind, Ill probably do the 2 AQ2200Ds and a Rockford Fosgate t400-4. Thats about 5000wrms. Would the 320 amp alt and 2 D3100s be good? Id use a S3400 for my starter
if you have enough power in your alternator to push your amps then yes, but if you dont have enough amperage from your alt, then you want to have some extra battery power in reserve
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
Thats true. also, its an easier install and a save $50.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Should I get 2 hifonics brz2400.1Ds and wire each sub down to 1 ohm. That would give each sub 2400 watts instead of 2150 wrms with perfect voltage. Or is the audioque aq3500 the better bet
LMFAO so true
:blush:
  • Who's Online   0 Members, 0 Anonymous, 1257 Guests (See full list)
