Don Cheech Posted April 27, 2010 Report Posted April 27, 2010 hi,i am a total noob in car audio, and am going to buy a JL W6v2 H.O. Wedge and i want to know i can hook an MRP-M500 which is 100 watts less than the sub -Subwoofer Features: * 12" W6v2 Subwoofer loaded in a W6 H.O. Wedge Enclosure * Power Handling: o Peak: 1200 watts o RMS: 600 watts * Impedance: 2 Ohms mono * Polypropylene cone woofer * OverRoll Surround * W-Cone * Floating-Cone Attach Method * Plateau-Reinforced Spider Attachment * Radially Cross-Drilled Pole Piece * Massive Forced-Air-Cooled Aluminum Alloy Frame * Highly Linear, DMA-Optimized Motor System * Huge Diameter, Progressive Roll Spider * Co-Extruded Double Lead Wires * Ultra-Long Voice Coil * 1-year SonicElectronix.com warranty (subwoofer only) Enclosure Features: * Chamber-coupled, slot-ported, rear-firing design * Designed specifically for the W6v2 subwoofers * Chamber-coupled port design optimizes the subwoofers sound * Weight: 65.0 lbs * Dimensions: 19"D1 x 12-3/4"D2 x 30-1/4"W x 16-3/4"H MRP-M500 Features and Specification SPECIFICATIONS CEA-2006 Power Ratings * CEA-2006 Power Rating: (4 I? @14.4V Ƈ% THD+N, S/N: 75dBA, ref:1W into 4 I?) 300W x 1 RMS Power Ratings * Per channel into 4 Ohms: (@ 14.4V Ƈ%THD+N, 20Hz - 200Hz) 300W x 1 * Per channel into 2 Ohms: (@ 14.4V Ƈ%THD+N, 20Hz - 200Hz) 500W x 1 Sound Tuning * Crossover: 50Hz-200Hz, -24dB/oct. (Low-Pass) * EQ (Equalizer): Bass EQ (Fixed Frequency): 50Hz 0 to +12dB * Subsonic Filter: 15Hz (Fixed), -24dB/oct. Dimensions * Foot Print (WxHxD) mm: 270mm x 60mm x 242mm * Foot Print (WxHxD) in: 10-5/8'' x 2-23/64'' x 9-33/64'' * Heat Sink (WxHxD) mm: 210mm x 60mm x 242mm * Heat Sink (WxHxD) in: 8-17/64'' x 2-23/64'' x 9-33/64'' General * Power Requirements: 14.4V DC (11V to 16V) * Input Sensitivity: 0.2 - 4.0V * Frequency Response: 20 -200Hz (200Hz/-3dB) * Speaker Impedance: 4 or 2 I? * Signal to Noise: 100dBA FEATURES Install * Terminal Layout: Two-Sided * Screw Mount / Wire Cover: Integrated Wire and Mounting Screw Terminals General * Amplifier Type: Class-D (Digital) * Channel Design: 1 Channel (Mono) * Thermal Control: Thermal Management Control * Power Supply: DC-DC PWM Power Supply * Power Supply Design: MOSFET Power * Board Circuitry: STAR Circuitry * Current Protection: Over-Current, Over-Voltage and Thermal Protection * Power Indicator: Top Mounted Blue LED Power Indicator * RCA Output: Gold Plated RCA Input Connectors * Speaker-Level Inputs: Speaker Level Inputs * Crossover: Adjustable Low-Pass * Connector Plating: Gold Plated Input, Output, Power and Speaker Terminals * Board Design: Dual Sided Glass Epoxy PC Board * Gain Control: Continuously Adjustable Gain Control
Skullz Posted April 27, 2010 Report Posted April 27, 2010 Sure can and there is other good gear out there for the same price if you happen to ask around here. BTW: whats your budget look like? 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
ktm300 Posted April 27, 2010 Report Posted April 27, 2010 That would be a good start. That amp will be ok. If you can find a little bigger amp it would be better for the future. It will leave you room to expand in the future.
Don Cheech Posted April 27, 2010 Author Report Posted April 27, 2010 im trying to keep it under a $1000, iv already bought an alpine cde-103bt head unit for $200
Skullz Posted April 27, 2010 Report Posted April 27, 2010 For that price you can build a really decent system far exceeding the jl setup you were looking at. http://www.audioque.com/aq/ http://www.t3audio.com/core.mdv/subwoofers.html http://dcsoundlab.com/ https://ssl.perfora.net/www.ficaraudio.com/sess/utn154bd6415432ae3/shopdata/0050_Speakers/product_overview.shopscript http://www.soundsolutionsaudio.com/store/categories/Sub-Woofers/ 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
