getmoney Posted July 2, 2007 Report Share Posted July 2, 2007 (edited) ok i have a kenwood KAC-9152D amp and it has 2 negative and positive speker terminnals and i am very confused beacause the amp is suppose to be Mono. I know how to wire my subs to 2 ohms on a regular mono amp with one set of negative and positive speaker terminnals but not two. so i was wondering if anyone could please help me with this. here is a pic of what im talkin bout Edited July 10, 2007 by getmoney Quote Link to comment Share on other sites More sharing options...
ChevyBoy Posted July 2, 2007 Report Share Posted July 2, 2007 the 3400 is, so i would imagine this one is too. Quote Link to comment Share on other sites More sharing options...
getmoney Posted July 2, 2007 Author Report Share Posted July 2, 2007 ok thanks cause i might buy one Quote Link to comment Share on other sites More sharing options...
getmoney Posted July 2, 2007 Author Report Share Posted July 2, 2007 please read the first post thanks Quote Link to comment Share on other sites More sharing options...
sean 371 Posted July 2, 2007 Report Share Posted July 2, 2007 um the meaning of aeroports means its flared. so no pvc cant be used as an aeroport. but yes it can be used as a circular port. Quote A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall Link to comment Share on other sites More sharing options...
getmoney Posted July 2, 2007 Author Report Share Posted July 2, 2007 oh i didnt know Quote Link to comment Share on other sites More sharing options...
TheDave Posted July 2, 2007 Report Share Posted July 2, 2007 Check this site http://www.partsexpress.com/webpage.cfm?We...;rak=port_tubes Quote Link to comment Share on other sites More sharing options...
Ernesto Posted July 3, 2007 Report Share Posted July 3, 2007 um the meaning of aeroports means its flared. so no pvc cant be used as an aeroport. but yes it can be used as a circular port. Wrong...You can make your own flare using PVC...So yes you could use PVC piping to make aeroports. Quote Link to comment Share on other sites More sharing options...
getmoney Posted July 5, 2007 Author Report Share Posted July 5, 2007 Wrong...You can make your own flare using PVC...So yes you could use PVC piping to make aeroports. how? please explain Quote Link to comment Share on other sites More sharing options...
ChevyBoy Posted July 6, 2007 Report Share Posted July 6, 2007 you get a heat gun and heat up the end real good and take a round object, or a mixing bowl and "push" it into the end. Quote Link to comment Share on other sites More sharing options...
