taysextreme Posted April 28, 2010 Report Share Posted April 28, 2010 So my question is regardless of what resistance you wire the subs to, what is the best practice on making the actual connection with the subs coil? i know no one solders to the actual coil. so what do you use? especially when use 8gauge speaker wire to link your subs together. p.s. i did use the search button and been reading threads for about three hours lol ( all about ohms) thx for the info Link to comment Share on other sites More sharing options...
Decaf Posted April 28, 2010 Report Share Posted April 28, 2010 So my question is regardless of what resistance you wire the subs to, what is the best practice on making the actual connection with the subs coil? i know no one solders to the actual coil. so what do you use? especially when use 8gauge speaker wire to link your subs together. p.s. i did use the search button and been reading threads for about three hours lol ( all about ohms) thx for the info u wire ur subs depending on what the final ohm load u want ur amp to see every single subwoofer has either a push terminal, screw terminal or spade terminal which either accepts 12-8g raw wire, or the spade for lower powered subs (<3-400w) (unless dd/aq or psi recones) if u want to use 8g to wire subs together like in parallel wiring, just make terminals on the box and connect the wires at the box so u dont have to twist and shove them in one terminal on the sub u have lots to learn, enjoy Link to comment Share on other sites More sharing options...
Guest Posted April 28, 2010 Report Share Posted April 28, 2010 alot of people use bolts. they put the bolt on the box and put the speaker wire (with a lug on it) on one side the the same on the other side to connect to amp. you can do lets say 8 bolts for a 4 coil woofer. one for each + and -. or you can clean it up by combining wires...if you have the right ohm load...terrible explanation Link to comment Share on other sites More sharing options...
taysextreme Posted April 28, 2010 Author Report Share Posted April 28, 2010 alot of people use bolts. they put the bolt on the box and put the speaker wire (with a lug on it) on one side the the same on the other side to connect to amp. you can do lets say 8 bolts for a 4 coil woofer. one for each + and -. or you can clean it up by combining wires...if you have the right ohm load...terrible explanation thanks thats pretty much what i wanted to know. I think I might implement this bolting system. thx kranny Link to comment Share on other sites More sharing options...
HHR Ed Posted April 28, 2010 Report Share Posted April 28, 2010 Actually people do solder connections to their subwoofers. I do in some setups. Ever hear of direct wire leads? Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion Link to comment Share on other sites More sharing options...
Decaf Posted April 28, 2010 Report Share Posted April 28, 2010 Actually people do solder connections to their subwoofers. I do in some setups. Ever hear of direct wire leads? right, but at some point 99% of us are connecting those direct leads to wire at the box terminals or twisting them to the wires that go to the amp Link to comment Share on other sites More sharing options...
HHR Ed Posted April 28, 2010 Report Share Posted April 28, 2010 right, but at some point 99% of us are connecting those direct leads to wire at the box terminals or twisting them to the wires that go to the amp No, its only 98% ha. I've also ran wire into the box and soldered onto that. Or, I use bolts. Or, if the woofer has a nice terminal, I will put 8awg to the terminal and run 1 piece of wire straight from that terminal, through a hole in the box sealed with gooey stuff, then it goes right into the amp. If I am doing any parallel or series wiring, I will do it at the amp terminals. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion Link to comment Share on other sites More sharing options...
taysextreme Posted April 28, 2010 Author Report Share Posted April 28, 2010 thx for all the advice from everyone p.s. if you have more info keep going Link to comment Share on other sites More sharing options...
raytard Posted April 28, 2010 Report Share Posted April 28, 2010 x2 on wire through box with goo and parallel at amp if needed simplest is best, no need to complicate things with nuts and bolts and washers and shit Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC Link to comment Share on other sites More sharing options...
