tdc3187 Posted April 29, 2010 Report Posted April 29, 2010 So I am going to start building another box because I made a stupid noob mistake. I'll never make that mistake again. So I want to design a box for my equipment. Port in the middle (3"x12.5"x15" tuned to 35), a little less height on box, a little more depth on box, 45's on all edges. If i flare my port say an inch on the mouth will it affect my output. I would like this to be a great box please help with the flares. Viper 5902, big 3, 1/0 Rockford wiring, 2 xs d3100, mechman 300a, pioneer avic-z1, 2 dc 12xls, Rockford t2500.1bdcp, Rockford t1000.4ad, Rockford t2 6.5 comps, damplifier Build log: http://www.stevemeadedesigns.com/board/topic/102584-carbon-fusion/
HHR Ed Posted April 29, 2010 Report Posted April 29, 2010 1" helps a bit with turbulence. But not with smooth tuning. To receive the full benefit of a flare, you need a bigger flare. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
Neo_frog Posted April 29, 2010 Report Posted April 29, 2010 The flares will reduce the turbulence at the port mouth and make for louder/cleaner response. Generally unnoticeable to the ear. Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
tdc3187 Posted April 29, 2010 Author Report Posted April 29, 2010 Threw some numbers around today, I came up with a 9" port mouth, 3" port, right above 2.1 cubes per 12 after sub, port, bracing, etc. I'll post a autocad pic in a little bit. Viper 5902, big 3, 1/0 Rockford wiring, 2 xs d3100, mechman 300a, pioneer avic-z1, 2 dc 12xls, Rockford t2500.1bdcp, Rockford t1000.4ad, Rockford t2 6.5 comps, damplifier Build log: http://www.stevemeadedesigns.com/board/topic/102584-carbon-fusion/
tdc3187 Posted April 30, 2010 Author Report Posted April 30, 2010 So here is the final draft (crossing finger at that statement). Internal measurements are 38.5*17.17*12.5=4.94cubes. minus .32 for subs and .406 for the port is 4.2 total. As long as I don't have any issues with the port this time i'll be ok. pic... Viper 5902, big 3, 1/0 Rockford wiring, 2 xs d3100, mechman 300a, pioneer avic-z1, 2 dc 12xls, Rockford t2500.1bdcp, Rockford t1000.4ad, Rockford t2 6.5 comps, damplifier Build log: http://www.stevemeadedesigns.com/board/topic/102584-carbon-fusion/
tdc3187 Posted April 30, 2010 Author Report Posted April 30, 2010 look good? should I bump the port to 4"? Should 3" be good with a large mouth? I know this is a lot of trial and error, but I know you guys have been through it in the past. Thanks!! Viper 5902, big 3, 1/0 Rockford wiring, 2 xs d3100, mechman 300a, pioneer avic-z1, 2 dc 12xls, Rockford t2500.1bdcp, Rockford t1000.4ad, Rockford t2 6.5 comps, damplifier Build log: http://www.stevemeadedesigns.com/board/topic/102584-carbon-fusion/
tdc3187 Posted May 2, 2010 Author Report Posted May 2, 2010 whooohoooo, Getting bass box pro!!! Hopefully that will help with making sure this box SLAMS. Viper 5902, big 3, 1/0 Rockford wiring, 2 xs d3100, mechman 300a, pioneer avic-z1, 2 dc 12xls, Rockford t2500.1bdcp, Rockford t1000.4ad, Rockford t2 6.5 comps, damplifier Build log: http://www.stevemeadedesigns.com/board/topic/102584-carbon-fusion/
