donellk Posted May 6, 2010 Report Posted May 6, 2010 Well i guess its over heating! I have a temp set up in my cadi! 2 re sxx 15"s on a 2010 ss tx2k amp 1 run of 0g too a battery in the trunk 0g grounds! 4g going to the tx2k with a 200amp inline fuse! The rcas are Dedicated from my sub out on my clarion cz500! Basically ill ride for about 30-45mins then my amp will start going in and out of protect till the amp cools down =/! anyone have any ideas on what it could be or should i just order a couple cooling fans? Box i think is 7cu tuned to 31hrz amp is at 1ohm bridged (2 dual 4ohm re sxx 15"s) Voltage drop is about .5 while driving (1000-2000rpm) 1.0 at idle Team Xtreme Amperage Xtreme Audio Innovations XtremeAudioInnovations.com Facebook.com/xtremeaudio321 basics of a 4th order ~ 1993 Toyota Pickup~ 4 linked c notched bagged Fiberglass door panels (5 speakers per door)
dugee81 Posted May 6, 2010 Report Posted May 6, 2010 Sounds like you should try upgrading the size of your wire, I'm thinking four gauge doesn't handle a 200 amp current too well. 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
donellk Posted May 7, 2010 Author Report Posted May 7, 2010 Sounds like you should try upgrading the size of your wire, I'm thinking four gauge doesn't handle a 200 amp current too well. Yah but its only like 4ft from the back battery and theres no way im getting 1/0g into that amp! All the other wires are 1/0g! Team Xtreme Amperage Xtreme Audio Innovations XtremeAudioInnovations.com Facebook.com/xtremeaudio321 basics of a 4th order ~ 1993 Toyota Pickup~ 4 linked c notched bagged Fiberglass door panels (5 speakers per door)
n8ball2013 Posted May 7, 2010 Report Posted May 7, 2010 how do you bridge a mono amp. is it the trx2000d or the tx1.2000? THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
donellk Posted May 16, 2010 Author Report Posted May 16, 2010 how do you bridge a mono amp. is it the trx2000d or the tx1.2000? Dont ask me ask soundstream lol they dont have a 2010 trx2000d I have the 2010 TX1.2000D! But I think this is a ground problem! I am gonna run 0g to the amp with reducers and ill have a 7" 0g ground if that doesnt work ill upgrade to the TX1.2600D Sound Stream said it might be that the ohm load of the coils are lower then 4 so i might need a amp that half ohm stable! Team Xtreme Amperage Xtreme Audio Innovations XtremeAudioInnovations.com Facebook.com/xtremeaudio321 basics of a 4th order ~ 1993 Toyota Pickup~ 4 linked c notched bagged Fiberglass door panels (5 speakers per door)
