inm Posted May 15, 2010 Author Report Posted May 15, 2010 Thanks for that, but I guess I wasn't clear enough with what I wanted. Like, on the PSU, I know there are multiple wires, most of which I don't use, I need to know which wires to use, and then I would like to have a diagram with fuses and stuff drawn in. Again, thanks for trying anyway, that is technically what I asked for Quote On 2/28/2013 at 2:52 PM, Chaise said: "Now spread your butt cheeks so I can zap your asshole."
hdorre Posted May 15, 2010 Report Posted May 15, 2010 Thanks for that, but I guess I wasn't clear enough with what I wanted. Like, on the PSU, I know there are multiple wires, most of which I don't use, I need to know which wires to use, and then I would like to have a diagram with fuses and stuff drawn in. Again, thanks for trying anyway, that is technically what I asked for You need to use the +12 volt rail (yellow) and the ground (black). In order to turn on the PSU, you need to connect the only green wire with a ground (black wire). I'll edit the diagram tomorrow morning. Do you also want all the speakers and RCAs drawn in? I can't do the sub because I don't know if you have in wired in series or parallel Quote On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
splmark Posted May 15, 2010 Report Posted May 15, 2010 Why don't you buy a power supply that adds up to the fuse rating of the amps or close to it then go from there. They are not cheep but it will give you the power you need plus it only has a + and - on it so u shouldn't be able to mess anything up. I haven't checked but I don't think a computer power supply putting out that much current. Oh and like said above if you don't know how to read what the instructions say that come with the psu and u have to ask then don't risk your parents house burning down Quote http://www.termpro.com/dbdrag/memberalbum/34416a0.jpg
MACnonsence6 Posted May 15, 2010 Report Posted May 15, 2010 why would u need to reciever if ur not going to use it? u state that u wana have an amp running 4 speakers and another amp running a sub so why do u need a head unit have the rca's go to eather a source out ie computer dvd player w.e unless u just wana use the sterio for volume controll in wich case it would be easyer to just get a rca in line controll ebay that shit the easyest way for you to do this shit and not get hurt or harm anything else is to get a really good yellow top battery or anything that can hold a charge for a long time and a car charger that plugs into the wall sept turn the charger off at night when ur not using it. that is prolly ur best bet. uall also need to wire in a switch to turn the amps off at night so they dont drain ur battery ie from posotive of the battery to a switch then to both remotes Quote I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
Tek Posted May 15, 2010 Report Posted May 15, 2010 why would u need to reciever if ur not going to use it? u state that u wana have an amp running 4 speakers and another amp running a sub so why do u need a head unit have the rca's go to eather a source out ie computer dvd player w.e unless u just wana use the sterio for volume controll in wich case it would be easyer to just get a rca in line controll ebay that shit a head unit can control the system much easier than a computer or dvd player. Quote
