SAZ-3500D
Hell-Razor
Well hopefully a somewhat easy answer to an easy question, what is the phase knob for on a SAZ-3500D? I looked in the instructions and did not see anything. I also googled around but found no real help. Right now its set at zero...
leave it at 0 or all the way down.
It comes in handy when strapping 2 amplifiers together. or another example would be if your running 2 subs and 2 amps and 1 sub is inverted, you could change the phase 180 degrees so that the inverted sub is firing the same as the normal sub. You could do the same tho wiring the other sub backwards.
All it changes is the direction of the woofer firing.
Phase is one of those features you dont use on single amp installs in most cases, but may gain a few tenths in a burp application if you know what your doing.
  • Who's Online   0 Members, 0 Anonymous, 745 Guests (See full list)
