This is copied from ROE but seeings nobody ever replies with any insight on my build I figure I'll post on other forums to get some feedback on it.
If anything doesnt make sense its because its a few posts put together etc.
Well I'll be changing this out yet again next year (maybe) when I get the money for my HDC3's.. But current box I blew my port board out the center (cracked it on both sides of all 8 screws 4 top 4 bottom and the glue joint). So time for a new box, or shall I say Boxes. Well this is as far as I made it for today, but got quite a bit accomplished in the 3 hours I spent working on it. (Not to mention I cant just leave everything out, I have to store everything in my shed which is a pain right now with another 4x8ft of 3/4mdf in there.
Doing 2 seperate boxes to gain more cuft per sub this time around.
Each box is right around 2 cuft after and port disp.
Onto the pics :D
Painted the port after gluing it in, then put the side once I was happy with the 4 coats of paint.
Another shot of the painted port.
Side painted before putting it on.
All done other than cutting the sub hole, fiberglassing all the joints and putting the top on. I plan to do atleast the bottom and 4" up the sides if not all of the box in resin. This way if my trunk leaks my box wont be destroyed again.
Car - 99 Neon Sport
Batt - 1 Redtop up front On 200A Excessive Amperage alt
Sub - 2 12" Kicker L7's in ~2 cuft @ 36hz each on a Xtant X1001 @ 1 ohm
Front Highs/Mids - JVC CS-FS6 and Infinity 6022i on Xtant A2002
Rear Highs/Mids - None
HU - Pioneer DEH-P8600MP
1/0 wire ran thru entire car aswell as big3
DB - 144.5 @ Dash.
Well got a little bit of work done today, nothing big but got the first box nearly done. All thats left to do is fiberglass the top to the sides from the inside and coat the box in resin to make it water proof incase the trunk decides it needs water in it again >.<
Really happy with the way it has came out so far, I know I dont really need to fiberglass the corners but I want to be sure there are no leaks and hey added strength cant hurt.
Car - 99 Neon Sport
DB - 144.5 @ Dash.
Well Spent the most of my day after work (got out early) working on cuttin the boards and building the second box. Got them both glassed on the insides and resin'd on all joints outside (to ensure no leaks, I hope). After getting everything cut and mostly together I realized that some boards were ~1/8th off, double checked them and realized the tip on the tape measure was loose through the entire build of this box. Luckily the port was very close to where it should be (less than a 1/16th off) so I just let it go. Well heres a bunch more pics of the build up of the box, Hoping to get my amps and old box out of the Neon tomorrow and get these fitted in so I can figure out how to mount the amps and such.
Mostly done with cutting all sides.
Bottom, Side and Rear plate screwed and glued.
Painting of the port internal.
Port internal and what I'll consider external all painted up.
Where the port will be on the box, painted before putting port/front on.
Port and Front plate before I put them in the box.
Just a shot of my work area, saw horses FTW.
Screwed and glued in.
You can faintly see my markings of where the port is on the outside, I build the L port and put the front plate on so I can put them on the top/bottom plate and outline where the will be. Saves time and hassle this way, no measuring or anything.
Starting to glass.
Boxes both done, Took me a few hours to glass the inside of the top plates. Plus a break to snack haha.
Car - 99 Neon Sport
DB - 144.5 @ Dash.
Well got what I felt was alot accomplished today, tear out of all the old and running into problem after problem with the new :D. Apparently I measured wrong and the boxes wedge way too tight between the strut towers so new plan and I like it better anyhow.
Old box/amp setup
No thats not a Edit on the plate, my licence plate does say B4SSB0Y :D
The power
My Big 3
Mess in the back after uninstall
Reason I originally did 2 boxes, Its a pain with a Neon to put a box in >.<
Old box
Car - 99 Neon Sport
DB - 144.5 @ Dash.
The new layout
19 month old son learning how to build a sub floor :)
Trying to use a drill, I showed him how to put screws in when I was installing this.. Didnt want him droppin my Ryobi so I gave him my old drill
Chillaxin in the trunk LMAO
OK OK Ive seen everyone craw into walls, Done it plenty myself but I got the man for crawing into 2 cuft boxes!
Making of the faceplates, got them all cut, just gotta cut the holes for the subs/port out then put everything back in again.
What it looked like before I took the boxes out to router the front facia...
Will be more updates later tonight, not even gonna bother posting more on ROE... Only a few knowledgable people left over there anyhow.
Car - 99 Neon Sport
DB - 144.5 @ Dash.
Looks good nice build. Always fun when you can get the kids involved.
2011 Meca World Champ S3
Team Truth Hertz
Team DC
Nice setup. And for your water problem you said you had, check the tail light seals as they tend to go bad on 95-99 neons. I had one a few years ago and had the same problem.
Yesss, looking very good dude!!! This ain´t ROE´s forum haha, you´ll get more replies here unless you have a explorer and you are from Panama like myself hahaha, no to many replies on my thread :yahoo:
