XS Power
Hello i was wanting to know if running a D3100 would be enough battery for a RF2500-1bd and a 400 watt 4 channel amp? also i am wanting to to know which iBar i would need in order to run two battery terminals on it? thanks in advance
07 Corolla S
2-p3 15's in a custom fiberglass box powered by a p1001bd, Fosgate punch series components that hit 140.1 on Term Lab
07 Magnum R/T
1-??? sub powered by RF 2500-1bd, Big 3, 2-shuriken bt-120 batteries.
99 Ford F-150 Reg Cab
2-10in Powerbass ps subs in a MTX Thunderform box Powered by ASA1000.1. Hit 132.4 on Term Lab
How many amps is ur alt? Also, what impedance would the t2500 run at and whats it rated for at that impedance?
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Give Nathan a call, he is really nice guy, very helpful. i think you would be ok with the 3100 up front.
R.I.P '01 blazer you treated my ears well until your transmission blew up.
New Project
[top secret]
149.0 db on music driver window open; so close
I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean....
I swear... sometimes I wish I was retarded so I could just agree with everyone x.
my alt is going to be a 300 amp, the amp will be running about 3100-3300 watts at 1 ohm, 4 channel at about 60 watts per channel. Also the battery is in the back on the magnum(dont know if that makes a difference or not). i would call nathan but dont want to do that until i am ready to buy(dont want to bother him) just figured if he was on here he would answer when he got around to it.
07 Corolla S
07 Magnum R/T
It sounds good to me! What do you have upfront battery-wise? You should look into a D3400 if you have the money
LMFAO so true
:blush:
The Ibar will not work with the D3100 now. When it was redesigned we put the larger terminals on it, and the ibar doesn't fit on the new terminals. You can add multiple ring terminals on the terminals though with no problem.
You should be good with the D3100. What is your 300amp alternator going to put out at idle? That is a very important thing to look at when getting your alternator. I do not recommend our 300amp alternators to anyone that is going to run it as a daily driver alternator, unless they are running a dual alternator set up, because it doesn't charge at all at idle.
it is said to put out 160 at 800 rpm but am waiting to see what the other companies say. if go with ring terminals do you lose power running with them or not. if do what battery would you recommend that will take the ibar and allow for two battery post to it
07 Corolla S
07 Magnum R/T
You will get batter connection with ring terminals really.
thanks alot i guess i have been miss informed about ring terminals
07 Corolla S
07 Magnum R/T
  • Who's Online   0 Members, 0 Anonymous, 677 Guests (See full list)
