jeyrapboy Posted May 18, 2010 Report Posted May 18, 2010 Okay guys i am stuck. I have a 1993 4x4 jeep grand Cherokee and i have looked everywhere and there is no where to run the power wire through the firewall. No unused grommets that i can find and all the ones that i can find are not big enough. Someone told me that there is one but i dont see it. If you have any ideas shoot them my way. I am trying not to drill through the firewall just yet. Thanks BTW i am using 8gauge power wire. Quote
BeatBox Posted May 18, 2010 Report Posted May 18, 2010 8g power wire you fit that thru anything. if the batt is on the drivers side try going thru where the "hood unlach" cable goes thru thats where i run my wire thru when its on the driver side. Quote
bigredishott Posted May 18, 2010 Report Posted May 18, 2010 Whats wrong with drilling? Just be sure to use rubber wire grommet! Quote Alpine CDA-9847 HU F Highs 2x Infinity Kappa 60.9CS Powered by Eclipse EA4200 Glass door panels R Highs Infinity Ref. 9622i powered by HU 3x RF Punch HX2 RFD2210 Powered by MTX Thunder 81000D Box Vol. 3.259 before displacement, Tuned 36.6, Port area 54"
StreetSlappah Posted May 18, 2010 Report Posted May 18, 2010 Okay guys i am stuck. I have a 1993 4x4 jeep grand Cherokee and i have looked everywhere and there is no where to run the power wire through the firewall. No unused grommets that i can find and all the ones that i can find are not big enough. Someone told me that there is one but i dont see it. If you have any ideas shoot them my way. I am trying not to drill through the firewall just yet. Thanks BTW i am using 8gauge power wire. i had the same problem i had a hole through my firewall just big enough for 8 gauge wire but i bought a drill bit the ones that cut through metal and made the whole bigger and after i grinded it down so it wouldnt cut my wire and i ran my 0 gauge like that Quote Refs-(b.f.) 99vic, WCA Rusty(x3) Nathan@XSPOWER, Ampjunkielikeme, Bread0710, AmiCreations (s.t.) REsLaPz, PandaGT(x2), Keiferacing, Juicemane (t.w.) Powski, Big gil[/center] Build Log http://www.stevemeadedesigns.com/board/topic/77726-sss-celica-dc-buildupdate-611-finished/ 2005 subi STi 380whp 355whp 17" gold bbs 5% tint all around w/sunglare strip JVC dvd double din Knuconceptz 4ga wiring XS Power! Big 3 8" SAv2 d2 1800 audiopipe
bigredishott Posted May 18, 2010 Report Posted May 18, 2010 i had the same problem i had a hole through my firewall just big enough for 8 gauge wire but i bought a drill bit the ones that cut through metal and made the whole bigger and after i grinded it down so it wouldnt cut my wire and i ran my 0 gauge like that That's kinda crazy imo, I would have at least put 4 or 5 layers of black tape on the wire were it passes thru. Quote Alpine CDA-9847 HU F Highs 2x Infinity Kappa 60.9CS Powered by Eclipse EA4200 Glass door panels R Highs Infinity Ref. 9622i powered by HU 3x RF Punch HX2 RFD2210 Powered by MTX Thunder 81000D Box Vol. 3.259 before displacement, Tuned 36.6, Port area 54"
BeatBox Posted May 18, 2010 Report Posted May 18, 2010 That's kinda crazy imo, I would have at least put 4 or 5 layers of black tape on the wire were it passes thru. thats what i did once, hey i didnt have a grommet Quote
JCiarlino Posted May 18, 2010 Report Posted May 18, 2010 Whats wrong with drilling? Just be sure to use rubber wire grommet! I've been running my shit for about three years now with no grommet and I haven't had a problem. Quote
jeyrapboy Posted May 18, 2010 Author Report Posted May 18, 2010 8g power wire you fit that thru anything. if the batt is on the drivers side try going thru where the "hood unlach" cable goes thru thats where i run my wire thru when its on the driver side. Well the batt is on passenger side. But i will still look into it. Thanks Quote
Freshman6969 Posted May 18, 2010 Report Posted May 18, 2010 in my jeep i dont have a grommet, due to i have 4g and 8g in the same whole, but i had to drill it bigger, but i dident have a powerfull enough drill inorder to do it so i just took a smaller bit and chipped away at it, but like above, the hood unlatch is a good place to look Quote Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog
jeyrapboy Posted May 18, 2010 Author Report Posted May 18, 2010 Whats wrong with drilling? Just be sure to use rubber wire grommet! Well there is nothing wrong with drilling BUT i would rather that be a last resort type thing. I have some rubber grommets on the way. Should be here along with my amp tomorrow. Quote
