corona_jeff Posted May 22, 2010 Report Posted May 22, 2010 This DD amp is easily worth 4x more than the AQ20, pal. Apparently you didn't see the Daredevil logo that increases output by 75%... so a sundown 3000 is worth more then a DC 3000 because it says sundown on it? it cost more then the AQ because of the huge markup DD has by ONLY selling to dealers. just about every post ive ever seen you make is un knowledgable and not needed. Dustin fromjeffs computer BTW
chud Posted May 22, 2010 Report Posted May 22, 2010 so a sundown 3000 is worth more then a DC 3000 because it says sundown on it? I didn't mention a word about Sundown. Didn't mention DC either. But if you want to split hairs, I'm a big fan of the zenon designs and wouldn't mind owning a few PAI-3000.1's. it cost more then the AQ because of the huge markup DD has by ONLY selling to dealers. el oh el just about every post ive ever seen you make is un knowledgable and not needed. Yeah, I'm obviously "un knowledgable". Maybe you should avoid reading what I have to say. You can't fix stupid
corona_jeff Posted May 22, 2010 Report Posted May 22, 2010 Specifications Model AQ20 Input Sensitivity 0.15V ~ 5V Variable Subsonic Filter 10Hz ~ 50Hz @ 24dB/Slope Variable Low Pass Filter 35Hz ~ 250Hz @ 24dB/Slope Tested Voltage 12.5V THD ≥1% Cont. Power @ 1 ohm 8000w Damping Factor 150 < Dynamic Power 20,000W Signal to Noise Ratio 100dB < Dimensions (mm) 980mm (L) x 300mm (W) x 76mm (H) Dimensions (in) 38.58in (L) x 11.8in (W) x 3in (H) Weight 63 lbs notice the tested voltage is 12.5 volts and thd is > 1%. not to mention it looks JUST like the old z series amps and even the new se
OFFTHAHOOK_INC Posted May 22, 2010 Author Report Posted May 22, 2010 so a sundown 3000 is worth more then a DC 3000 because it says sundown on it? it cost more then the AQ because of the huge markup DD has by ONLY selling to dealers. just about every post ive ever seen you make is un knowledgable and not needed. Dustin fromjeffs computer BTW your just mad u dident get 1...lol OFF THA HOOK,INC [email protected]
corona_jeff Posted May 22, 2010 Report Posted May 22, 2010 I didn't mention a word about Sundown. Didn't mention DC either. But if you want to split hairs, I'm a big fan of the zenon designs and wouldn't mind owning a few PAI-3000.1's. youre right but saying the DD is different and worth more just because of the case is pretty dumb ... i used that analogy for demonstration purposes of you probably thinking the sundown was worth more because it said sundown instead of DC or vica versa ... el oh el youre dumber then i thought .... Yeah, I'm obviously "un knowledgable". Maybe you should avoid reading what I have to say. you commented on my post. Edit: you were the one complaining you couldnt afford DD no?? but this is worth 4x more? your a fuckin tard hole.
chud Posted May 22, 2010 Report Posted May 22, 2010 @ corono jeff: I'm sorry that my blatant and obvious sarcasm flew over your head. You can't fix stupid
corona_jeff Posted May 22, 2010 Report Posted May 22, 2010 your just mad u dident get 1...lol how do you know i dont have a few on the way??
corona_jeff Posted May 22, 2010 Report Posted May 22, 2010 @ corono jeff: I'm sorry that my blatant and obvious sarcasm flew over your head. this is dustin btw .... and im sorry i obviously cant see sarcasm on a computer screen .... i guess im the only one?
OFFTHAHOOK_INC Posted May 22, 2010 Author Report Posted May 22, 2010 how do you know i dont have a few on the way?? b.c im pretty shure u dont OFF THA HOOK,INC [email protected]
chud Posted May 22, 2010 Report Posted May 22, 2010 this is dustin btw .... and im sorry i obviously cant see sarcasm on a computer screen .... i guess im the only one? So, you actually thought I was serious when I said; "the daredevil logo increases output by 75%"? just...wow. You can't fix stupid
