Adding on to my corolla, CHEAP setup.
Get a box and amp kit then get this stuff for way less than $500. With a good box this will outdo the powered sub, but do whatever you can afford. If it was me personally and i wnted a small setup i wold do the below.
Hifonics ZXi 8010 5 Chan Amp- $189
RE Audio RE8D4- $78.99
This will give you 55x4 @ 4ohms and 300x1 @ 2 ohms
Eye Kandy Kustomz
2414 E. Napoleon St.
Sulphur, LA 70663
(337)313-3121
[email protected]
Eye Kandy Kustomz Page
My Page
for a $500 budget here you go A soundstream 5 channel amp, Rockford Fosgate 8" punch, bandpass box (like you wanted)and a complete 4 gauge amp wiring kit. you wont need a battery or anything like that because you wont be drawing alot of power it'll just make your alternator work harder Sonic Electronix
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
Thank you! Idk about the box type, it just happen to be bandpass. I'm totally fine with a sealed.
Let me look over all these and respond to you guys in a little. The help on this forum is amazing, thanks!!!!!
I'm still new to all this, can you explain to me exactly what "fade" is.
I'd wanna run a 5 channel one day but not with this setup/car. I originally just wanted a CD player but got the speakers as a gift so I'm building off the budget setup I have.
I don't think I'm gonna get an amp for the speakers now, just the sub/amp pkg. All I have to do is wire it up.
Is there anything else I would need? As in any other wiring or a new battery? I don't want my car shutting off on me. I usually listen only when driving and with me and a few friend with the windows up, I don't open everything up and bump it so I'm not looking for loudness.
fade from front to back, like the balance is left and right.
I don't think crutchfield throws in a amp wire kit. I just order some stuff for my uncles corvette, deck, amp, enclosed sub, and wire kit. We also got all this on a $600 budget. You have a deck and speakers already! You should be able to get some decent stuff for $500. Also, put the deadener on your doors, and maybe the floor in the front. It would be kinda of a waste in the trunk, with such a small sub. Anyways good luck on your lil build! We love pics here!!!
Alpine CDA-9847 HU
F Highs 2x Infinity Kappa 60.9CS Powered by Eclipse EA4200 Glass door panels
R Highs Infinity Ref. 9622i powered by HU
3x RF Punch HX2 RFD2210 Powered by MTX Thunder 81000D
Box Vol. 3.259 before displacement, Tuned 36.6, Port area 54"
This is what is has come down to, 2 options:
I think I'll go with setup 2. Option 1 is my backup.
Option one:
-Sound Ordnance B-8 P (8 0) -watt powered bandpass subwoofer.
Option two:
Box (sound ordanance bass bunker)
Amp kit (best buy)
RE Audio RE8 (d4?)
Link to the box.
http://www.crutchfield.com/p_777BB835S/Sound-Ordnance-Bass-Bunker.html?tp=127
Question:
1. Will the sub be 2 ohm stable if I run it like " 55x4 @ 4ohms and 300x1 @ 2 ohms. I don't wanna stress it and have it break.
2. Is the RE8 the same as the REX8D4?
3. Anyone recommend ported over sealed?
4. Will I need anything else like speaker wire, or to upgrade "the big 3"?
5. What gauge amp wire? Is 8 okay? I saw someone mention 4.
Any other advice or recommendation at all. This total just under 400 which is awesome.
Thank you all so much!!!
You can prob save a few dollars if you order an amp kit online! I would look for everything online! I like to save money when I can!!!
Alpine CDA-9847 HU
will do, I just looked around, it'll save me like 10 bucks.
btw: do u know of any amps like the one above, that one is apparently discontinued and i can't find it any places.
  • Who's Online   0 Members, 0 Anonymous, 1934 Guests (See full list)
