so im getting 1 1%" Fi BTL down the road and was wondering if this box would be good enough.
* Single 15" ported/vented subwoofer enclosure
* Dimensions in inches: 21" Width x 15.75" Height x 16.5" Top depth x 16.5" Bottom Depth
* Volume per sub: 1.75 cubic feet
* Machine precision cut mounting holes
* 3/4" heavy Dusty Construction
* Multi layers of high-grade glue ensure long life and no air leaking out
* High quality spring loaded terminals
* Dado end panels
* Mounting Depth: up to 16.5" (enough depth for any sub on the market)
* Designed, tested, and engineered to work with most of today’s popular woofers. These enclosures are built with the quality additives needed to maximize the performance of any sound system.
Im guessing you meant to put 12" btl. The box seems like prefab. Don't buy because the tuning is usually extremely high and it's really small. After sub displacement, it'll be too small
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Double post..srry
Edited by hdorre
LMFAO so true
:blush:
no he meant 15 the % thing is a five... not to mention the box description says sing 15" sub enclosure.
And man i wouldn't buy a pre-built box. Chances are that box is tuned really high. Fi recommends at least 3 cuft for a BTL 15 anyway and that box is only 1.75.
Edited by 99xtremedime
a0xp5g.jpg-2 AQ HDC3 15's-'Nendo 3KWP @ .5-7.75cuft @ 30hz-Alpine CDA-117-4 Cadence PA 8's
-AQ 200.2-2 AQ Supertweeters-XS Power D3400-270a Mecman Alt
-Knu Konceptz Wire
LMFAO so true
:blush:
idk y i put a % tbh but yea... i meant 15" lol. so I should get a custom box built?
Whatever it is, why buy a BTL and put it in a POS box.
cuz im poor now?
Yes, itll probably sound a LOT better if its built properly
Dude, building a box can be cheaper than buying a prefab.
This is completely true if you build your own box. If its custom built by someone else, this may still be true depending on rates
Edited by hdorre
LMFAO so true
:blush:
Exactly what i was gonna say. Pay someone on here to design you one- $0-15, 3/4" MDF $25.99 (around here that is), Screws ~$5, Glue ~$5-10 depending on how much you use. There thats under 50 dollars and that is less than you will pay for any pre-fab box of the same size or quality. And not to mention it will be built to the specs of your speaker and get every bit of peformance out of it!
-Knu Konceptz Wire
