Ok so I have been bumping this same amp for about 2 years now. Its been a beast. Recently though its been turning off for some reason while I'm driving around. Generally I could just jiggle the cables a little bit and it would turn on. But the other day it just stopped working and won't turn on anymore. I've re-ran all the cables and wires and even changed my ground location thinking that was the problem. Still nothing. So I decided, it must be the remote wire. I have the remote wire hooked up with with the headunit on the same remote coming from the inside of the dash. I'm not sure if this would be a problem or not.
'01 Honda Accord EX 4 Cyl4/18/13
Started new build
Headunit: JVC kdx250bt
Sub Amp: Hifonics Hifi 2000d
Door Amp:
Rear Amp:
Sub(s): SQ HDC3-12
Battery(s): Stock
Wire: Knu 1/0 and 4awg
Big3:
Make SURE your ground is GOOD. and the ground wire is bigger than the power.. Check for a pinch in your radio wire. See if it's hot when on.
Think it would be a good idea to check with a volt meter to see if there is voltage going through the wires, even the remote?
Started new build
Door Amp:
Rear Amp:
Sub(s): SQ HDC3-12
Battery(s): Stock
Big3:
I was having the same problem and it came down to a bad ground
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
one quick way to see if it is the remote wire is just use a small jumper wire from the hot to the remote hookup and see if it turns on.
So just stick a wire connecting the pos input to the remote input?
Started new build
Door Amp:
Rear Amp:
Sub(s): SQ HDC3-12
Battery(s): Stock
Big3:
If it is some internal electrical problem, then you obviously won't be able to fix it...
Is your amplifier mounted on the box?
From what I hear, that can cause it to fail internally more often than if it isn't, not sure if that is a myth or not though
:D Good luck.
Yeah, it's mounted on the back of the box with rubber grommets. That was something else i was thinking of, what if something came loose on the inside. But if that other trick doesnt work than I'm gonna take it apart and see whats wrong with it.
Started new build
Door Amp:
Rear Amp:
Sub(s): SQ HDC3-12
Battery(s): Stock
Big3:
Alright so i took a volt meter to it to check what wires were getting voltage and not. The pos and neg read 14.2v while the truck was on. At first when i checked the remote it wasn't even reading out on the meter. Than i checked it a second time and the amp turned on and started working. I dont really understand how/ why it started working when i hadnt even done anything but tested the volts. I think somehow it just needed a small jump between the remote and ground. But it's all working again. Thanks for the tips guys.
Started new build
Door Amp:
Rear Amp:
Sub(s): SQ HDC3-12
Battery(s): Stock
Big3:
  • Who's Online   0 Members, 0 Anonymous, 1052 Guests (See full list)
