Question about an AMPS output
Level33.1
Actually no. It depends on the topology of the amp though.
Changing the impedance of the load actually changes the acoustic characteristics of the amp and the efficiency.
Usually a lower ohm load will be less efficient at turning the 12v DC power input into its AC voltage output.
Some amps are designed to compensate with firmware that regulates voltage and current. And because a speaker is a reactive load, the exact impedance is always changing and the voltage and current is also always changing at various frequencies.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
In an amp the output voltage with any load stays the same, its only the current that changes right?
In an ideal world, yes. But as the current increases the voltage decreases, due to energy losses in the amp, mostly in the power supply FETs due to Rds(on) (the resistance of the FET itself) and the inherent inefficiency of inductive power transformers.
10.x volts fo' life!
  • Who's Online   1 Member, 0 Anonymous, 582 Guests (See full list)
