Current through my one amp's case (one of the XXX 4ks)?!
The only thing I can think of is that the amp is hosed (no protect light and it does work however)... I have 2 XXX 4ks both on the same power and ground, but one of the 4k's shocked the hell out of me this morning (just finishing up my build) so I hooked up a volt meter and there is massive amounts of current running through it. According to the meter 90 volts DC (not sure if amps do AC, but if they do make that 200 volts). Sorry I don't really know how amps work in detail, but that is where I'm heading now to find out.
Anyone have any ideas? Current is running through the case itself and the screws which mount the case to the rails and heat-sink. Any guesses anyone might have would be appreciated. I have a call into SS but god only knows how long it will take to get a response.
NOTE: Yes power is clean, yes the grounds are right, no no wires are touching the case, it's not bolted to metal, etc.
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
That sounds like a fun way to wake up
I bet the manufacturer didnt leave enough space between the PCB back side, and the casing, check that area out, see if anything is arcing
Thanks man and no it wasn't fun at 9am haha... Half asleep adjusting the gain and BAMO (as juicy as a wall socket).
My guess was that something had broken loose and was grounding out, but I wasn't going to pop it open until I got some more info (plus I have to dig it out). Shit like this happening when you are a hair away from being done is so forking anoying... :angry:
Thanks again!
Pioneer X8500
Second Skin
2 270a Mechman Alts
whats under your amp?
rf amps used to tweek out when we mounted them on back seats where it was uneven. when we torqued down it twisted the case and grounded something that made it arch to amps next to it. fixed it with a board below it.
Maybe I'll try jossling it around and see. It's mounted to a board in an amp rack that sits on my floor. Seen here
Pioneer X8500
Second Skin
2 270a Mechman Alts
It's forked, off for warranty repairs. :angry:
Pioneer X8500
Second Skin
2 270a Mechman Alts
  • Who's Online   0 Members, 0 Anonymous, 1755 Guests (See full list)
