DDlincolnon22's Posted June 2, 2010 Report Posted June 2, 2010 "15-inch subs work in 3.0-4.5 net cuft." ...straight from the AQ site. Where is that at on the site? I've been looking for it lol. Team Digital Devastation My on-going 9518 build
Twiztidsetup Posted June 3, 2010 Author Report Posted June 3, 2010 Measurements would help, then we can give ideas. I'd tune from 35-38hz, that should give good spl and decent low notes. I pretty much know that I need as much room as possible. I thought that I had enough but its a real tight squeese in the back of a s10 extended. The subs are basicly going to be bairly touching the seat. I have 38" height , 43" width and 17 depth , so ill have around 13 square feet without the port and give an avg 1 foot squared for the port and thats only 3 feet per 15" sub thats with 3/4inch mdf and I will be putting bracing. But thats not including the subs. Its pushing it but I hope it will do fine for a temporary vehical until I get a blazer.
bassl0va Posted June 3, 2010 Report Posted June 3, 2010 I pretty much know that I need as much room as possible. I thought that I had enough but its a real tight squeese in the back of a s10 extended. The subs are basicly going to be bairly touching the seat. I have 38" height , 43" width and 17 depth , so ill have around 13 square feet without the port and give an avg 1 foot squared for the port and thats only 3 feet per 15" sub thats with 3/4inch mdf and I will be putting bracing. But thats not including the subs. Its pushing it but I hope it will do fine for a temporary vehical until I get a blazer. I would use more than .75" MDF, but if you do use it, brace it well. 3 cubes per 15" is fine. My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build This forum has a massive boner for ridiculous electrical upgrades.
Twiztidsetup Posted June 4, 2010 Author Report Posted June 4, 2010 I would use more than .75" MDF, but if you do use it, brace it well. 3 cubes per 15" is fine. Im going to put a alot of 2by4s teed off on the inside walls and between the cutouts, I heard on some forums that its actualy better than just putting a double front on it. My ferret just got put to sleep an few hours ago. Sucks so bad
bassl0va Posted June 5, 2010 Report Posted June 5, 2010 Im going to put a alot of 2by4s teed off on the inside walls and between the cutouts, I heard on some forums that its actualy better than just putting a double front on it. My ferret just got put to sleep an few hours ago. Sucks so bad I'm not talking about just on the front, I mean thicker wood all around, especially since your doing 4 15"s Damn, sorry bout that bro . My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build This forum has a massive boner for ridiculous electrical upgrades.
Twiztidsetup Posted June 6, 2010 Author Report Posted June 6, 2010 Whell I have the sdc2.5 15's comming in 2 days and talked to someone that runs audioque alot and he basicly said with the ammount of room I have, I will only have 2.4 square feet a peice with the subs in the box. So he said just break in these 2 subs and install them in a large box and run about 1200rms to each and it will be just as loud as the 4 in a smaller box but risking a recone in the future. So it sounds all legit, I will just do that for now until I get a 2 door blazer walled. Things changed for the better as I can now save up for a new transmission and dont have to worry about getting 3 batterys or a h.o alt and a shit load of 0awg. Ill be bracing the hell out of the inside walls to lose some square feet as 11-12 feet squared is a little too much for 2 of thsee subs. Hopefully it will be louder than my 4 12" cvr's
