Arnold and Chris got the best answers in this thread
Unloading is unsafe, and usually causes a wind tunnel, not resonating air
If a port is blowing air like a compressor air nozzle, tuning is probably to high
Questions I didn't see is
"How large is your box?"
and "How is your box ported/ tuned dimensions of the box internals, and dimensions of the port?"
it could be quit possible the box was tuned wrong, maybe you expected a 30hz tuning, but got a 40 hz tuning, and the woofer will unload with a lot of chopped and screwed music or music that is being constantly played below tuning
One way to check things is get a test tone CD that steps in single digits, 30hz, 31hz, 32hz
Find the point where the woofer is barely moving at all, almost a standstill
That should be port tuning
write that number down
Now keep going low from that number ( Say you found the cone barely moves at 40hz)
Now while testing the tones, going lower, you will more than likely get the most wind- not resonating wind, but wind tunnel type wind at about 20hz
So, what I'am guessing is, your listening to music well below port tuning
Simple solution, after finding the tuning freq, use a subsonic filter to filter bass below that frequency
The harder solution, tear out, rebuild, tune lower
I highly doubt you will actually damage that SMD woofer, those things are obviously built like beasts
but again, if your running rated RMS, or higher, you may be getting in to dangerous territory with the box/filtering left alone
like opening a hatch or rear door for ex?
Well you have to remember that majority of systems employ a box that has much lower internal space than the cab of the car. Trunk systems rely on the back side of the car (or sealed trunk) for extra loading if oriented that way. Walls are where you run into that type of problem. Each time you add more exposure to the outside air, generally the resonance spikes. Unless you know your response well, in bassboxing for example, you would have to start a bit lower and turn it up until you start to unload to get your best score. That's assuming you haven't tested and you actually care about your equipment.
But with normal trunk or hatch setups, depending on the size of the vehicle and position of the box, there's a chance that opening doors will barely affect the cone movement even though your peak frequency could change.
Here's my example from my last setup:
Enclosure: 19.7 cu; 2x DC LVL5 18s; 8kW
Sealed Cab: ~42 cu
Door: ~806 sq in.
Peak Sealed: 32hZ
Peak (one door open): 32-33hZ
Peak (both doors open): 51hZ
And doing the little test I mentioned above, I did start to hear some distortion with both doors open on normal music.
EDIT: spelling
Edited by Neo_frog
Need an install? Hit me up.
[email protected]
nice testing and info neo frog...that's alot of good info... :drinks:
RE se xxx 18d2 (4)
Audioque 2200 (2)
DC Power 270XP blue
3 C&D fr310
Stinger wiring
CDT components
