Small tip, don't tune it to 33hz, too low for the AQ drivers, if u tune them that low you won't get very loud.
I would stick with recommended tuning which is around 35-38hz.
So 35hz at lowest, if u want to be louder and still hit higher bassnotes, i would tune to 37hz.
I don't know why people recomended tuning below 35hz, because that's maybe a good tuning for most drivers, but not for the HDC3's.
thanks dude. will do. i will tune to 37 thenn :good:
anyone? how does
2 runs of 1/0 awg from alt to front batt + (Shurkin BT35)
2 runs of 1/0 awg from front batt + (Shurkin BT35) to rear batt + (Shurkin BT80)
2 runs of 1/0 awg from front batt - (Shurkin BT35) to chassis
2 runs of 1/0 awg from front batt - (Shurkin BT35) to motor ground
2 runs of 1/0 awg from rear batt - (Shurkin BT80) to chassis
1 run of 1/0 awg from rear batt +/- to Audioque AQ2200D amplifier
1 run of 4 awg from rear batt +/- to Audioque 4X90 amplifier
sound
sounds good just dont forget all the fuses you will need.
also do you have a big enough alternator for this setup? i'd imagine a stock cavi only having like a 50 amp alt LOL
F/s: 2 custom made boxes, for 1 12" and 2 12" hit me up I'll let em go cheap
im thinking of getting one of these. which one would u pick
http://www.dbelectrical.com/p-4428-cavalier-22-high-output-200-amp-alternator-99-00-01-02-8275-2.aspx
http://www.dbelectrical.com/p-4454-beretta-cavilier-corsica-high-amp-alternator-93-95-7861-7.aspx
http://www.dbelectrical.com/p-4433-cavalier-high-output-alternator-87-88-89-90-91-92-93-7886-11.aspx
i've never heard of those brands so im not too sure but i'd try to stick with reliable well known brands like DC power and Iraggi alternators.
i cant find anything else. can u?
Never used them, but, i´ve read A LOT of good reviews about them!!
