S Dime 420 Posted June 7, 2010 Report Posted June 7, 2010 Ok, so I just ordered 2 15" MOFO's and I'm looking to build a box. What's the difference between Aero, Slot, and L ports? Which has the best sound qaulity? Oh, and I've also heard good things about T-line boxes, can somebody help me out? If anybody in the Sacramento area has a vehicle for sale for less than $1,500 get at me. I'm open to almost anything that runs.
devil4u2c Posted June 7, 2010 Report Posted June 7, 2010 Basically an L port and a slot port are the same thing, you end up with an L port if you need the extra port length and have to make a bend in it to fit it in the box. I have never used Aero ports, but from what I have seen they seem to be a little easier to install. Its all the same thing when you come down to it ( how you tune the box) but Its mostly a cosmetic preference. Feel free to chime in if I am wrong, because I am no expert.
finkster Posted June 7, 2010 Report Posted June 7, 2010 aero ports are more efficient than slotted, but slotted is much cheaper to make. And also the aero ports can be re-adjusted easier. DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
Socky Posted June 8, 2010 Report Posted June 8, 2010 Aero ports move quiet alot of air because of the turbulence factor. Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz
chapo123 Posted June 8, 2010 Report Posted June 8, 2010 im using aeros in my next box because it makes it so much easier. paid 30 bucks for 2 4" ones but i heard they are very good and i hope they are lol Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal? heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked. i dont want woofer broke like bass sound clip clip and voice coil overheat 2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
