Tinting over defroster lines
Tek
Is there anything different that I need to do when tinting my rear window that has defroster lines as opposed to tinting a normal window?
It should be the same as any other window my buddy just has his done and they did the same on the back as they did all the other windows.
K thanks just wonderin. Ive heard the lines make bubbles
I talked to my buddy he said that you have to work a little harder around the lines. But he has had his done for about a year now and no problems.
i heard that if you want to remove it you cant without messing up the defroster lines, this was probably only said because the shop was lazy and didn't feel like taking it off.
Who knows! mines tinted over the defroster lines and it works just fine
2002 ford explorer
200 amp rewound alt
single 18" Fi btl fully loaded
2 1750's
2 c&d tech 88amp/hr batts
2 ought wiring
cdt component set up front, cdt coaxials in back
Kenwood eXcelon KDC-X693
Im not worried about removing it, I just want it to stay on without bubbles.
You can't clean the window with a razor blade.... Gotta use steel wool.
ur talking about the prepping before right?
Removal is a pain. Need some very strong window cleaner with amonia(spelling?) a trash bag, and a warm day. But installing is the same and the lines don't make much if any of a difference. The curve of the back window is a real bitch though to get the tint to fit just right. For mine we did it in two layer that meet exactly on a defroster line. We fitted it on the outside using a heat gun to warm it and bend it into shape with a lot of soapy water and baby powder to keep it from tearing. The put it in :D
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
