wL<3bass Posted June 11, 2010 Report Share Posted June 11, 2010 My blazer did this horribly for months in the cold... I replaced every pulley and device on my truck except for the crank pulley... swapped two AC compressors, two power sterring pumps, two water pumps, 3 alternators, 4 idlers, 3 tensioners... Changing all of those made absolutely no difference I just started it one day and it hasn't done it since. Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references... Link to comment Share on other sites More sharing options...
Toady Posted June 12, 2010 Author Report Share Posted June 12, 2010 Dang bro thats alot of money. It ha;ppens when temperatures are 76 degrees, then its faintly heard when the temperatures hit 105, 109 (Texas Temperatures lol) Im just tired of it, IDK If my belt is too tight, i went with a 1 size smaller than stock belt because of the overdrive pulley on my alt. Should i get the factory size belt instead?? Link to comment Share on other sites More sharing options...
Toady Posted June 13, 2010 Author Report Share Posted June 13, 2010 Would a small belt sqeal?? Link to comment Share on other sites More sharing options...
Toady Posted June 13, 2010 Author Report Share Posted June 13, 2010 I guess im just going to get A gates green stripe factory belt size, and see what happens. I hope it takes away the problem if not then im giving up altogether Link to comment Share on other sites More sharing options...
Loudcav Posted June 13, 2010 Report Share Posted June 13, 2010 upgrade to the gatorback it cant cost that much more Link to comment Share on other sites More sharing options...
Toady Posted June 13, 2010 Author Report Share Posted June 13, 2010 upgrade to the gatorback it cant cost that much more I've heard horror stories about the gatorback Link to comment Share on other sites More sharing options...
Iraggi Alternator Posted June 14, 2010 Report Share Posted June 14, 2010 just by reading first post.... either belt is too small... or batts are getting drained while car is off... or batt is bad... or batt needs to be charged. Link to comment Share on other sites More sharing options...
Toady Posted June 15, 2010 Author Report Share Posted June 15, 2010 just by reading first post.... either belt is too small... or batts are getting drained while car is off... or batt is bad... or batt needs to be charged. The Battery would make the belt squeal?? Link to comment Share on other sites More sharing options...
Loudcav Posted June 15, 2010 Report Share Posted June 15, 2010 The Battery would make the belt squeal?? when the battery is low it forces the alt to work harder to charge the battery Link to comment Share on other sites More sharing options...
Toady Posted June 15, 2010 Author Report Share Posted June 15, 2010 That makes sense, Tomorrow i will charge my battery completley, and i will see if it still does it, I dont know whether or not to get a new belt or not and if i do, i dont know what size to get. Stock size, or 1 size smaller because of overdrive pulley Link to comment Share on other sites More sharing options...
