Toady Posted June 9, 2010 Report Posted June 9, 2010 When i first crank the car in the morning i hear a squeal coming from my serpentine belt is, I've tried buying a New belt, New Auto Tension-er, New Idler Pulley, And it wont stop!! It's getting Very annoying and i would love some help to fix this problem. It does it when i first crank it up after i let it sit awhile it will stop squealing at idle and will squeal as i drive faster, as the day gets warmer, and i make a couple of blocks, it will go away. Later after i get done riding i will crank it up and it doesn't squeal at all. And this Cycle repeats each day, I could really use some help, im about to lose it..
LoudNLow931 Posted June 9, 2010 Report Posted June 9, 2010 Could just be wet, has it been raining by you? 2008 Dodge Ram 2500 6.7l Cummins 4 FT1s C1600.2 8 PWX 8s ONX2.100 Audio Technix Wiring & Sound Deadener My Youtube Feedback
tomypg Posted June 9, 2010 Report Posted June 9, 2010 Maybe the cold is making your belt slip? Or even condense so it is insanly tight and causing drag? That's all I can think of 1988 Honda City E Big 3 in 1/0 Venom 6x9 Venom 6.5 Components Response 4x100 midz and highs amp Fusion NV 2500.1: STOLEN 2 x 12 inch fusion nv subs 10 inch 5 doller subs in my doors PM me if you want help with electrical
UnderLoK Posted June 9, 2010 Report Posted June 9, 2010 Sounds like the belt is too tight and as it heats up is expanding. How much slack is there when you push on it (in an area where the is a big gap between pulleys)? If at first you do not succeed, you are doing it wrong! -ARSCheck out my walled TBSS build over here4 Fi Team 18s on 2 Cactus K9 DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500 Pioneer X8500 6 XS Power D7500, 1 3400S Second Skin 2 270a Mechman Alts
Toady Posted June 9, 2010 Author Report Posted June 9, 2010 do you have a mastercrap or gates belt? I think its A Gates Green Stripe, I Could be mistaken tho, i forgot which one it was, nut i also got it one size smaller than stock because of the overdrive pulley on my mechman alternator
Toady Posted June 9, 2010 Author Report Posted June 9, 2010 Could just be wet, has it been raining by you? Barely Any At All
Toady Posted June 9, 2010 Author Report Posted June 9, 2010 Maybe the cold is making your belt slip? Or even condense so it is insanly tight and causing drag? That's all I can think of Any way to fix this??
Toady Posted June 9, 2010 Author Report Posted June 9, 2010 Sounds like the belt is too tight and as it heats up is expanding. How much slack is there when you push on it (in an area where the is a big gap between pulleys)? Not much at all if any, i got one size smaller belt than stock, because of the Overdrive-Pulley
djdew23 Posted June 9, 2010 Report Posted June 9, 2010 spray a little belt dressing on it wile its running http://www.acehardware.com/product/index.jsp?productId=1295692&CAWELAID=319204635 Alpine IDA-X200 Car Digital Media Receiver AMP = power acoustik cpt1 2200d SUBS = 3 re audio 10" voodoo fuse and distribution blocks Voodoo Power Wire Voodoo RCA Leads
