REALLY ANNOYING (APPRECIATE HELP)
My blazer did this horribly for months in the cold... I replaced every pulley and device on my truck except for the crank pulley... swapped two AC compressors, two power sterring pumps, two water pumps, 3 alternators, 4 idlers, 3 tensioners... Changing all of those made absolutely no difference I just started it one day and it hasn't done it since.
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
Dang bro thats alot of money. It ha;ppens when temperatures are 76 degrees, then its faintly heard when the temperatures hit 105, 109 (Texas Temperatures lol) Im just tired of it, IDK If my belt is too tight, i went with a 1 size smaller than stock belt because of the overdrive pulley on my alt. Should i get the factory size belt instead??
just by reading first post.... either belt is too small... or batts are getting drained while car is off... or batt is bad... or batt needs to be charged.
The Battery would make the belt squeal??
That makes sense, Tomorrow i will charge my battery completley, and i will see if it still does it, I dont know whether or not to get a new belt or not and if i do, i dont know what size to get. Stock size, or 1 size smaller because of overdrive pulley
  • Who's Online   1 Member, 0 Anonymous, 1528 Guests (See full list)
