I'm about to do a air strut setup on my civic and wanted to know the part that will level my car out like when going into a turn keeps air in the strut and doesn't let it out when weight is changed..when my brother had cylinders on his civic and he took a turn the car kinda leaned as he turned...
You can use accumulators that will help a lot. You wont get as much travel out of the suspension if you run sway bars, but it will handle better. Honestly my hatch, before i put a ton of weight in the back of it, handled very well with cylinders. most imports i ride in dont ride very well. all i had done at the time is replace all the bushing with poly and had some custom upper arms on it. Anyways long story short as long as you run an 8 valve set up it shouldnt sway too badly :good:
Xterra * 69 Camaro * Audi S5
36 Ford * 51 Mercury
looking for wire sponsor :)
www.flyracing.com
