I forgot to order some spade terminals with my wire and the wire itself wont fit into the power input on my amp. I have some aluminum sheets laying around that i would think would be the perfect thickness to make my own spade terminal. Would it be a good idea to go ahead and make them out of the aluminum? Im only making two, one for the power and one for the ground connections on the amp.
'01 Honda Accord EX 4 Cyl4/18/13
Started new build
Headunit: JVC kdx250bt
Sub Amp: Hifonics Hifi 2000d
Door Amp:
Rear Amp:
Sub(s): SQ HDC3-12
Battery(s): Stock
Wire: Knu 1/0 and 4awg
Big3:
I see no reason it won't work, as long as you're confident in your fabrication abilities :)
1990 Jeep Cherokee 4X4
Pioneer DEH-P2900MP, Big 3 done in 1/0, 1 run 1/0 ran to amp
DAT HF1000.1 #007 powering a DC lvl4 15
DAT HR 4085 prototype powering 2 Selenium 6s and 2 no name tweeters running active
1st place in AS3 @ Surf City Sound Off, 140.8 @ 45hz @ the headrest.
rebuild coming soon to get a better score :)
"I regard the brain as a computer which will stop working when its components fail. There is no heaven of afterlife for broken down computers; that is a fairy story for people who are afraid of the dark."
Im a bit confident. I dont have any special tools for metals. Just my dremal and some good old pliers.
Started new build
Door Amp:
Rear Amp:
Sub(s): SQ HDC3-12
Battery(s): Stock
Big3:
X2
Alpine CDA-9847 HU
F Highs 2x Infinity Kappa 60.9CS Powered by Eclipse EA4200 Glass door panels
R Highs Infinity Ref. 9622i powered by HU
3x RF Punch HX2 RFD2210 Powered by MTX Thunder 81000D
Box Vol. 3.259 before displacement, Tuned 36.6, Port area 54"
I'd ssay a dremel and pliers will take a while, but should be fine :)
Unfortunately I lost my tin snips :(
Started new build
Door Amp:
Rear Amp:
Sub(s): SQ HDC3-12
Battery(s): Stock
Big3:
have a rabbit? those little fers seem to be able to make quick work of about anything.... lol.
anyways, yea a dremel should be able to eventually do it, a spade isnt that much different than a ring. good luck.
Well while in the garage i found myself some copper tubing that would be perfect for this since it already has the round shape I need. I already got two of them made within minutes. Just polishing them up and getting them ready to make a good solid connection.
Started new build
Door Amp:
Rear Amp:
Sub(s): SQ HDC3-12
Battery(s): Stock
Big3:
no pics of your craftsmanship?
Alpine CDA-9847 HU
