Ground question
I want to know if I should run my ground from the front battery to the back or should just ground it to a peice of the frame. I know everybody has alot opinions on which would give you more volts, thanks
If u are asking if you should connect the 2 battery negatives, than yes
One way to wire it is in parallel (positive to positive and negative to negative)
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
If you have the wire and the time and the space using a wire to connect both grounds directly together is the best option. If you can't/don't want to do this make sure your back batt is connected to the frame or as close as possible (the fewest welds thickest metal between them is what you want) with the paint scraped off and a solid sized bolt threaded into the metal.
I used my strut tower on my car but I plan on running a second wire for ground sometime.
  • Who's Online   0 Members, 0 Anonymous, 1046 Guests (See full list)
