programing is the easy part man you will c once u have it hooked up.
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
Yea i am going to read of it a couple of times before i do it so i am not trying to read it and program it at the same time.
little advise to help u. lets say u wanna go to option 6. press it 1.2.3.4.5.6 then press and hold. dont press and hole on six or u will go to option 5. make sense?
pioneer DEH-P8400bh
XS Power D1200
Shuriken BT-100
audioque 120.4
2 audioque 2200d
big 3
479-418-3056
Yea that makes sense. My buddy said its a lot easier then what it sounds like on paper.
You guys keep saying don't use t-taps but no one said why. Do they come loose or something? On my first install that I just recently completed I only used one t-tap and that was on my ignition wire because it was so short and hard to get to the t-tap was way easier to do than strip the wire and solder.
Also someone said to disable NPC. I was going to program it to "on" later today should I just leave it off then? My main concern is the alarm going off when I'm not in range. I can't find anything in my manual about silencing the siren and have it still page me if something happens while its armed.(What I like to call beat down mode) :) Other than disconnecting my siren but I actually want the siren some times, I just wish sometimes I could arm the system and disable to siren going off.
On the 5101 and 5701 installs, both booklets said that T-Taps are ok to use on anything but ignition wires due to the heavy current but that's with remote start as well. I honestly don't see anything wrong with them, I didn't use them because I didn't want to use them on my truck as id rather use a method I trust more :)
Never thought of that, so should I solder it for sure or can I get away with the t-tap? The alarm I installed is just temporary until I get enough money for something with more features, so I'm a little leery of making any permanent changes. I probably won't get a new one installed for 6 months or more.
Making your wiring connections
Before making your connections, plan how your wires will be routed through
the vehicle. For instance, the red 12V constant input and the remote start igni-
tion wires are often routed together to the ignition switch harness. In order to
keep the wiring neat and make it harder to find, you may wish to wrap these
wires together in electrical tape or conceal them in tubing similar to what the
manufacturer used.
There are two acceptable ways of making a wire connection - solder con nec-
tions and crimp connectors. When properly performed, either type of connection
is reliable and trouble-free. Regardless of whether you solder your connections
or you use mechanical type crimp-on connections, ensure that all connections
are mechanically sound and that they are insulated, especially when connecting
data lines in the vehicle.
Cheap electrical tape, especially when poorly applied, is not a reliable insu-
lator. It often falls off in hot weather. Use good quality electrical tape or heat
shrink.
Never twist-and-tape the wires together without soldering. •
Never use “fuse taps”, as they can damage fuse box terminals. •
If you use tapping connectors such as T-Taps (not to be confused with Scotch-
Locks), avoid using them in higher-current applications (constant 12V, ground,
etc.) These connectors are inferior in quality and should be avoided.
That's what the books state. Honestly thou, strip about 1/2 and inch of insulation off the wire, poke a pick threw it and wiggle the pick to make a hole, on the wire your splicing into the line, strip about an inch of insulation, poke it through the hole you just made, twist it around the wire and tape. I ran across a pic how to on it, ill try to find it.
Strip back about an inch of insulation from the middle of the wire being tapped. Use some type of probe (a dental pick or a small flat head screwdriver) to separate the wire.
Strip back an inch of insulation from the tapping wire, insert in the middle of the original wire, then twist them all together.
