Heres my box...
im doing two 3" aero ports that need to be 15" from end to end.
i need help deciding the best way to fire the ports.
thanks for any help. :good:
2003 Silverado
Kenwood 8120
Sundown SAX125.2
Hertz HSK165.4
Sundown SAZ1500
Deciding on subs
is that a down fire box? and what size/type of subs?
2007 Chevy Impala LS
1 Crescendo 3KWP
1Crescendo C1000/4
2 DC lvl 4 15's with lvl5 dual .7 coils
1Audio Control Matrix
1 Pioneer P880PRS
1 300 amp Iraggi alt
All power runs done with Knu flex 0/1 guage
1 optima yellow top under the hood
1 XS 5100 and two Deka's in the trunk
4 Crescendo MP-8 mid bass drivers
2 DB Drive p5 5 D Pro Audio tweeters
what are the box dimensions? if you need 15" on the port tube from the pictures it looks like you would need to fire the ports to the side, you could fire them elsewhere but you would need to bend them not sure you have enough room for elbows.
1 Crescendo 3KWP
1Crescendo C1000/4
1 Pioneer P880PRS
He could have them external upfiring. It depends how wide the box I'd though
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
by the way he has that box built it looks like the seats are going back in. not going to be able to do an external port with the seat on top of the box.
1 Crescendo 3KWP
1Crescendo C1000/4
1 Pioneer P880PRS
if it was me, i would grab a couple of elbows and put one on each side firing into the cabin. mounting depth on the lvl3 10's are 6.25 and your box kind of narrows some in the back, the elbows will give you the room you need to stay off that back wall and away from the bottom of the sub.
1 Crescendo 3KWP
1Crescendo C1000/4
1 Pioneer P880PRS
can i fire them both out of the drivers side?
if not will i run into any problems with the passenger side port being that close to the door, while the drivers side has more distance between the port and door?
2003 Silverado
Kenwood 8120
Sundown SAX125.2
Hertz HSK165.4
Sundown SAZ1500
Deciding on subs
i like this idea... regular pvc/abs elbows will work with this aero right?
http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=268-350
2003 Silverado
Kenwood 8120
Sundown SAX125.2
Hertz HSK165.4
Sundown SAZ1500
Deciding on subs
