Does box flex affect output?
I notice I'm getting a lot of box flex.
How do I stop the box from flexing.
If you are getting box flex, more than likely air is going to find somewhere to leak out of (where it isn't suppose to..), so if that is happening yes you are losing output. And also, after a while of a lot of box flex, the box will start falling apart.
To stop it, you can resin the inside of the box, and also put some metal dowels in the box. If the sub is pointed up, put the dowels vertical, if the sub is facing forward/backwards, put the dowels horizontally.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
what type of box? the only way your going to stop flexing is to brace the inside of the box. just remember that your adding volume to the box so that may effect the ability of your box to perform correctly.if you choose to brace your box you might want to use all thread doesn't take much room up at all.
2007 Chevy Impala LS
1 Crescendo 3KWP
1Crescendo C1000/4
2 DC lvl 4 15's with lvl5 dual .7 coils
1Audio Control Matrix
1 Pioneer P880PRS
1 300 amp Iraggi alt
All power runs done with Knu flex 0/1 guage
1 optima yellow top under the hood
1 XS 5100 and two Deka's in the trunk
4 Crescendo MP-8 mid bass drivers
2 DB Drive p5 5 D Pro Audio tweeters
It's a 4 cuft box with two 6" aeros.
So to do the all threads. I just drill the holes, slide it through and put a washer and nut on each end? Do I have to add a washer and nut inside the box?
thats pretty much it, don't think you need a washer and nut inside the box . washer and nut on the outside and you should be good to go.
1 Crescendo 3KWP
1Crescendo C1000/4
1 Pioneer P880PRS
Yes it will affect output. The box flex makes the air movement less efficient. You want your enclosure as solid as possible.
Eclipse cd7000
I put a washer and a nut on the inside too, becasue when only putting on the outside it squeeze's the box, when u put them on both sides and tighten the inside first ur not pulling the box together ur just making it more sturdy. On each of my 5/8 all thread there is 4 washers and 4 nuts. Once again, its my personal opinion that u put them on both sides because if not ur just squeezing the box together and not really sturdying anything ur actually making it easier to break..
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Lots of Second Skin Damplifier
Under Construction for 2017
yeah 4 washers and 4 nuts is more efficient since flexing goes both ways. ex. (in and out)
I know a lil about everything so dont call me Mr. Know it All.
Yeah that makes sense.
Thanks for the information guys...
:good: :good:
  • Who's Online   1 Member, 0 Anonymous, 1125 Guests (See full list)
