Tek Posted June 17, 2010 Author Report Share Posted June 17, 2010 http://www.strutmasters.com/Pontiac-Aztek-Air-Suspension-Rear-Conversion-Kit-p/-gm-mvr2-pa.htm looks like you have a coil over setup? and that will lower it? I was unaware of the coil over set up Quote Link to comment Share on other sites More sharing options...
Tek Posted June 17, 2010 Author Report Share Posted June 17, 2010 Ok I just need to know this: is therr Going to be a bad effect on my car if I use the product I originally posted? Quote Link to comment Share on other sites More sharing options...
Mr. Yuk Posted June 28, 2010 Report Share Posted June 28, 2010 yes.. im sure you have driven over a speed bump before a little bit too fast.. you know how that feels now imagine that feeling on every single bump/crack in the road. you are shortening the spring 3 inches so there will be a ton of tension on them already they will not compress like they are supposed to and you will have a very bouncy ride. I cant even believe they make those kits to be honest with you it has to be the most unsafe way to lower a car i have ever heard of. Quote Link to comment Share on other sites More sharing options...
WaTTz305 Posted June 28, 2010 Report Share Posted June 28, 2010 i used those. and im ridng good. theyrre a bit of a pain to put on but other than that theye good. only thing that changes in ur ride comfortability is speed bumps and other kinda large bump. the car wont be bouncy but the bump are kinda hard. so just take em slow. Quote Link to comment Share on other sites More sharing options...
