RickyFriery97 Posted June 23, 2010 Report Posted June 23, 2010 i have a XSpower D3100 and a D3400 my battery charger has a 2 amp trickle charge and a 10 amp fast charge should i use the 10 amp setting the get them fully charged? i think i saw somewhere that 2 amp mode would take a very long time to fully charge a xs battery Quote 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
clouduz Posted June 23, 2010 Report Posted June 23, 2010 I'd use 10 amp, I use 15a on my D3100 when it gets a little drained. Quote
Nathan @ XSpower Posted June 24, 2010 Report Posted June 24, 2010 10am would be best. Depending on how low the batteries are the 2 amp could take you 6 months. Quote
RickyFriery97 Posted June 24, 2010 Author Report Posted June 24, 2010 10am would be best. Depending on how low the batteries are the 2 amp could take you 6 months. well the batteries are brand new never been installed just wanted to give em a over night charge first but i had it hooked up on 10 amp mode and i put my stinger volt meter on it and while it was chargin it got in the 15 volt area but when i took it off it went back down to the 13 volt area is it ok for the battery to be in the 15 volt area while it is on the charger? Quote 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
Nathan @ XSpower Posted June 25, 2010 Report Posted June 25, 2010 well the batteries are brand new never been installed just wanted to give em a over night charge first but i had it hooked up on 10 amp mode and i put my stinger volt meter on it and while it was chargin it got in the 15 volt area but when i took it off it went back down to the 13 volt area is it ok for the battery to be in the 15 volt area while it is on the charger? Max voltage you would want to see while charging is 14.9v. Quote
RickyFriery97 Posted June 25, 2010 Author Report Posted June 25, 2010 Max voltage you would want to see while charging is 14.9v. ok thanks both batteries are resting at 13.0 after being off the charger over night so there good to go Quote 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
