DieselPB Posted June 26, 2010 Report Posted June 26, 2010 I want to wire a couple subs. To get a 2 ohm load, would I get a DVC 2 ohm sub or a DVC 4 ohm? I've seen wiring diagrams from Crutchfield and Rockford Fosgate. Crutchfield says 4 and Fosgate says 2, so what should I do?
hamel52 Posted June 26, 2010 Report Posted June 26, 2010 if you want to wire 2 subs to a 2 ohm load then you need 2ohm dvc subs. one sub to 2 ohm you need a 4ohm dvc sub.
MrSkippyJ Posted June 26, 2010 Report Posted June 26, 2010 I want to wire a couple subs. To get a 2 ohm load, would I get a DVC 2 ohm sub or a DVC 4 ohm? I've seen wiring diagrams from Crutchfield and Rockford Fosgate. Crutchfield says 4 and Fosgate says 2, so what should I do? 2 DVC 2ohm subs would give you 2 ohms or .5 ohms 2 DVC 4ohm subs would give you 4 ohms or 1 ohm F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
MrSkippyJ Posted June 26, 2010 Report Posted June 26, 2010 I want to have two subs. DVC 2ohm, and what amp are you planning on running? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
DieselPB Posted June 26, 2010 Author Report Posted June 26, 2010 I plan on using an AutoTek 1000.2 amp. 500x2 RMS 1000x2 Peak.
MrSkippyJ Posted June 26, 2010 Report Posted June 26, 2010 I plan on using an AutoTek 1000.2 amp. 500x2 RMS 1000x2 Peak. Then I would recommend 2 DVC 4ohm subs F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
DieselPB Posted June 26, 2010 Author Report Posted June 26, 2010 Then I would recommend 2 DVC 4ohm subs Ok, thanks for the help.
