fx4trucker Posted June 26, 2010 Report Posted June 26, 2010 how do i figure out the size of a box if im running more then one sub ? alpine head unit (freebee 2009 model)2 sets of eclpise 5.25 comp. speakers. 1. set is in the a-pilors 1. memphis mojo 2500 watt amp 1. rockford fosgate t2 15" dual 2 ohm wired to 4 ohm . seeing 600 watts 1. realm audio 600 watt 4ch
MrSkippyJ Posted June 26, 2010 Report Posted June 26, 2010 how do i figure out the size of a box if im running more then one sub ? If one sub needs 3 cubes, then two subs need 6 cubes. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Guest Posted June 26, 2010 Report Posted June 26, 2010 you mean what the manufacturer recommends? lets say one woofer you have needs 2cuft and you have 2 of them. then you would build a box that would be 4cuft. essentially its multiplication. 2cuft x (times) 3 woofers = 6cuft. edit: dammit the ninja has been ninja'd
BeachJoshua Posted June 26, 2010 Report Posted June 26, 2010 Locked yet? | S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s | SPL: 143.7 Sealed | 153.4 Port Wars
