blcrocker Posted July 2, 2010 Report Posted July 2, 2010 How possible is it that an amps RCA inputs could get messed up? Cause I think I've narrowed down my amp problem to the RCA inputs. I could be wrong, but im just curious. And if they are messed up how easy is it to fix? '01 Honda Accord EX 4 Cyl4/18/13 Started new build Headunit: JVC kdx250bt Sub Amp: Hifonics Hifi 2000d Door Amp: Rear Amp: Sub(s): SQ HDC3-12 Battery(s): Stock Wire: Knu 1/0 and 4awg Big3:
Alex K Posted July 2, 2010 Report Posted July 2, 2010 I've heard they're a big pain in the ass to deal with. I remember someone else having the same problem with rca inputs a while ago on here. 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something.
J-Lane Posted July 2, 2010 Report Posted July 2, 2010 I had a problem with that a long time ago with the rca inputs on my old amp. It's usually not to hard to re solder them inside the amp where they break loose but the issue is that sometimes they break loose due to poor design and there is a good chance they may break again.
blcrocker Posted July 2, 2010 Author Report Posted July 2, 2010 Alright, ill dismantle the thing again and take a closer look at em. '01 Honda Accord EX 4 Cyl4/18/13 Started new build Headunit: JVC kdx250bt Sub Amp: Hifonics Hifi 2000d Door Amp: Rear Amp: Sub(s): SQ HDC3-12 Battery(s): Stock Wire: Knu 1/0 and 4awg Big3:
sactownstang Posted July 2, 2010 Report Posted July 2, 2010 Make sure your rca wires are inserted with no stress on the amps female connector. That lil stress, with vibration can cause problems.
blcrocker Posted July 4, 2010 Author Report Posted July 4, 2010 took it apart again last night and saw that my fuse box/holder board on the amp looks burnt. Seems like it over heated there or arched across the fuses or something. Thinking about ripping that out and making a new one. My RCAs look perfectly fine on the board and dont move what so ever. So im betting it is the fuse holder/box thing. '01 Honda Accord EX 4 Cyl4/18/13 Started new build Headunit: JVC kdx250bt Sub Amp: Hifonics Hifi 2000d Door Amp: Rear Amp: Sub(s): SQ HDC3-12 Battery(s): Stock Wire: Knu 1/0 and 4awg Big3:
