DieselPB Posted July 7, 2010 Report Posted July 7, 2010 On a mono D amp that has 4 speaker wire terminals, would you get a 4 ohm sub and wire it to 2 for a 2 ohm load on the amp? And do that for both subs?
speedball1978 Posted July 7, 2010 Report Posted July 7, 2010 the reason the mono amp has 2 channels so you can connect 2 4 ohm subs with ease, run your subs parallel but make sure you run one sub to one channel and the 2nd sub to the other channel, the amp on the inside is actually connecting the 2 together to create a 1 ohm load unless your amp is rated for 2 ohm load...
Torres Posted July 7, 2010 Report Posted July 7, 2010 the reason the mono amp has 2 channels so you can connect 2 4 ohm subs with ease, run your subs parallel but make sure you run one sub to one channel and the 2nd sub to the other channel, the amp on the inside is actually connecting the 2 together to create a 1 ohm load unless your amp is rated for 2 ohm load... even if the amp is rated for a 2 ohm load, it will still wire (2) 4-ohm subs to a 1 ohm load. but like he said, the extra terminals are for easier wiring. both positives and negatives are essentially the same terminals, just connected together on the inside of the amp. if it was a real 2 channel amp, it would not be a mono amp
DieselPB Posted July 8, 2010 Author Report Posted July 8, 2010 So, even if there are 4 wire inputs, you should still wire it into only 2 inputs?
GioRF Posted July 8, 2010 Report Posted July 8, 2010 Just use all the terminals. The "two channels." One for each sub.
Guest Posted July 8, 2010 Report Posted July 8, 2010 So, even if there are 4 wire inputs, you should still wire it into only 2 inputs? think logically, why would they do that if they only wanted you to use 2 terminals instead of all 4. the reason there are 4 is for ease of wiring. you can either wire woofers like this and take the final + and - and wire it to one + and - on the amp. OR you can wire each woofer like this and take the final + and - from each woofer and wire them to the amp so they take up all 4 terminals. both of these ways will end up with a 1 ohm load since every single monoblock amplifier that has 2 sets of speaker terminals is bridged internally via parallel.
