How would u guys wire a D4 sub to a 2 channel 2 ohm stable bridgeable amp for the best output?
2010 Civic SI sedan: Crystal Black Pearl
All stock.
most likely the amp is 2 ohm stable per channel and 4 ohm stable bridged stereo
what amp
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
Kole. Ik ik. Im just gonna use it till i get a better one. Im short on moneyz right now.
All stock.
Id play it safe if you cant afford a new amp atm and go 1 VC per channel
Live life to the full... Then TURN THAT BITCH UP!
Ok. Thanks spitfire. And also, my amp sayd its 1920 watts. Any REALISTIC idea of what its actually putting out?
All stock.
less than 500
Eclipse cd7000
