A friend of mine bought be this sub: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=299-106 as a grad present. I want to use it as a home theater/gaming sub. It will be powered by a 5.1 receiver (yet to be determined which one.) We're debating on what kind of box to build for it. We plugged the T/s parameters into WinISD and it recommended a 13 cube box at 17Hz! :No: But we were thinking somewhere around 3.5-4 cubes at 22-26Hz. The sub is rated for 150RMS and will probably be getting about that. here's the two plans we have: 3.63 [email protected], with a 3x8 slot port, or [email protected] with a 2x8 port. Which would you recommend? Thanks in advance
3.15ft^3 tuned to 29-30
Our main concerns are how much port area we need and how low to tune for movies and games. I thought we should tune lower because of explosions and stuff like that, but I have never done HT before.
(I am helping him with design and construction.)
Too many projects, too little time...
You wanna tune somewhere between 20-25. I'm guessing that when you plugged it in, it gave you a design for a t-line. That's the only reason I can think of the box being so big.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
Not sure, think it may be glitching or something, because it said to only use a 4" tube port for that huge-ass box.
How much port area would you recommend?
Well I'd say that 2x8 port would work. Tune to 22 hz. You just don't want to tune too high, I had a 15 in a t-line that was at 19hz and it DOMINATED the lows. Movies were never the same
under construction
u hate c-fizzy?
If you want to use a round port, a 4" is enough for that driver. ~12 sq in. That is enough for a 10" sub with 6mm xmax.
It has a low Fs, so 22-25 Hz tuning will definitely work.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
