InfiniteRuckus Posted July 8, 2010 Report Posted July 8, 2010 IMO best way to cool it is to move the air back there with some fans. blocking the light will help to some degree but the real problem is the stagnant air that surrounds those amps (& it looks like you have a nice collection of them back there). with the air temp rising & zero fresh air coming in... the amps are only going to continue to get hotter & hotter while heating the air that surrounds them. good luck, looks like you have a nice setup going on
IH8PunkRok Posted July 8, 2010 Report Posted July 8, 2010 refrigerated water running across the heat sinks should do the trick look into that you dont have much room back there though and im not sure how large a unit would be -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
Rebel4055 Posted July 8, 2010 Report Posted July 8, 2010 refrigerated water running across the heat sinks should do the trick look into that you dont have much room back there though and im not sure how large a unit would be LN2 Would look cooler Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
techforce Posted July 8, 2010 Author Report Posted July 8, 2010 I was going to say put the windows down til I saw the pics. if you do fans can you funnel the intake from the outside? air will still flow but the smaller opening would cut down on the water and grime that gets in. you follow that? \/ type opening instead of | | or slant it to the back. instead of straight down Only problem is that there is no room to do that... The only place that I could do something like that would be on the side of the truck, to the right of the AQ amps... But... Do they make something for sideways vents???? I thought about a crap load of fans... but would only blow hot air around...
techforce Posted July 8, 2010 Author Report Posted July 8, 2010 refrigerated water running across the heat sinks should do the trick look into that you dont have much room back there though and im not sure how large a unit would be HMMMM.... You might be onto something!! How about a water cooler for a PC?!?!? I wonder if I could make that work?!?!?! retro fit some Hard Drive coolers on the amps...
Rebel4055 Posted July 8, 2010 Report Posted July 8, 2010 HMMMM.... You might be onto something!! How about a water cooler for a PC?!?!? I wonder if I could make that work?!?!?! retro fit some Hard Drive coolers on the amps... Make a copper block and it will! Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
IH8PunkRok Posted July 8, 2010 Report Posted July 8, 2010 HMMMM.... You might be onto something!! How about a water cooler for a PC?!?!? I wonder if I could make that work?!?!?! retro fit some Hard Drive coolers on the amps... thats exactly what i was thinking it should work very well -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
Rebel4055 Posted July 8, 2010 Report Posted July 8, 2010 thats exactly what i was thinking it should work very well The bad thing is if it leaked he will be a very mad techforce... Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
techforce Posted July 8, 2010 Author Report Posted July 8, 2010 The bad thing is if it leaked he will be a very mad techforce... I would use non conductive coolant...
Rebel4055 Posted July 8, 2010 Report Posted July 8, 2010 I would use non conductive coolant... You would be using what you think would be non conductive coolant.. I read stories that people lost hardware even tho they had that type of coolant. Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
