Major Voltage issues. FML
bingo try replacing the fuse first of all.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
have you checked voltage before and after the fuse holders?
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
it shouldnt make a difference
It will just be higher with the car on. Cant hurt to try it both ways but either way you should notice a difference
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
after that move on down the line. It seems like you are getting loss on your power wire so find out why. pull the panels check for nicks or major chunks missing things like that. check the terminal on the amp. make sure nothing is keeping you from getting a solid connection etc.
if you arent beating on it while you do this oyu shouldnt see any drop from front to back really. maybe a tenth or two. since you arent pulling major current then it should not need to be produced by your alt to recharge the battery
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
this doesnt make any sense. from the battery, the voltage starts at 14.8 and drops to 14.2. when you check the alternator, its putting out 13.2. the alternator generates the power and the 14.8 volts, so how is it so much lower from the alternator to the battery?? wouldnt it be the other way around?
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
chevy does weird things sometimes but i did over look that. im wondering if his cars alt is controlled by the bcm. Im willing to bet after he starts the car and lets it run the battery will drop down to the same voltage as the alternator.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 949 Guests (See full list)
