I am going to be running a Sundown SAE1200d at 1 ohm along with a jl 4 channel which is only going to be around 300rms. So i am thinking possibly around 2000 rms. Right now i have stock wiring with a 140 amp alt and stock battery. So as it stands i am going to do the big 3 with 1/0 along with a run of 1/0 to the sundown amp and then a run of 4awg to the four channel.And i will be putting in a deka battery up front in the next few months. Will this be adequate for this setup? Will i be fine running streetwires 1/0 that i bought to the sundown? I know that streetwires is not the best quality so should i scrap that and go with knukonceptz 1/0 and 4awg to both amps?
The help would be appreciated!
Kenwood kdc-x794
Boston Acoustics S60 components, S65 Coaxials
Jl J2-320.4
Sundown Audio Sae1200d
2 Sundown SA-12's D4
Car Quest NGT Extreme Upfront
Shuriken BT-60 inback
Big3
All Knu Konceptz wire
Ur probaly still get dim do the big 3 and but a small kentic bat and do a run of 1/0 to the back and the ur wire off the bat it would cost about the same as runing multiple runs from the front but that's just my opinon
im running about 1400-1500rms all together on a 70 amp alt and the big 3 and im dropping to like mid to low 13's so you should be alright.
i dont know ANYTHING about streetwires but if they dont have "true" wire sizes then definitely go with Knu.
I haven't really compared streetwires to any other 1/0 and i haven't opened the package but it seems like some fairly thick stuff. I might just get knukonceptz and craigslist the streetwires. Will something like this work fine? My link
Kenwood kdc-x794
Jl J2-320.4
Big3
Street wires are made by stinger. I have never used them but I know that they are made by stinger. :shrug:
01 2dr ExploderBuild log2 18" DC Level 6's (M3's)DC 10k5 XS d3100's, DC 390 alt100' shok ofc cable
Team ShokTEAM SUB SONIC ADDICTION
I will probably just go with knu konceptz wire since everyone seems to be please with their products. And without replacing the factory batter could i run a kinetiks hc800 and the big 3 without issue?
Kenwood kdc-x794
Jl J2-320.4
Big3
ok so here is my plan as i posted originally i am going to be running somewhere around 2000rms. (I think). So i will be doing big 3 with 1/0, I will have a run of 1/0 20 feet. From there i will be hooked up to a hc800, then 1/0 to the mono and 4awg to the 4 channel. Will this work fine with a stock battery up front and a stock 140 amp alt? And for grounding everything can i get away with running the grounds from the amps to the hc800 then to the frame from there with 1/0?
Kenwood kdc-x794
Jl J2-320.4
Big3
this will work fine. just remember to fuse your power wires to help prevent any fires from happening.
:werd_msword:
8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee :DClick to see J00bles' Youtube Channel
:werd_msword:
Just making sure but fuse close to front battery and close to rear battery correct?
Kenwood kdc-x794
Jl J2-320.4
Big3
  • Who's Online   0 Members, 0 Anonymous, 2819 Guests (See full list)
